New pressure plate install problem
Old Mar 24, 2008 | 06:17 PM
bboixtc's Avatar
Default New pressure plate install problem
I ordered an 8lb fidanza flywheel and oem exedy clutch off ebay.
When I went to install the pressure plate over the clutch (with the alignment tool of course) I aligned the three pins and the pressure plate still doesn't sit flush over the clutch. When I tightened the 6 10mm 12 point in a criss cross pattern, when I went to tq them down at 19ft/lbs, the head of one of the bolts broke.
Why isn't it sitting flush? The clutch is on the right way. When I put the OEM clutch on (the worn one) the pressure plate sat closer but not flush.
Old Mar 25, 2008 | 02:39 PM
bboixtc's Avatar
Default Re: New pressure plate install problem (bboixtc)
anyone?
Old Mar 25, 2008 | 03:11 PM
dagle's Avatar
how far is it off?
Old Mar 25, 2008 | 04:06 PM
bboixtc's Avatar
Default Re: New pressure plate install problem (dagle)
it sticks out maybe 1/4 of an inch those 3 tabs barely go in. When the clutch isn't in there, it sits fine up against it. And when I put the worn down oem clutch, it sat a tad bit closer.
Old Mar 26, 2008 | 08:10 AM
bboixtc's Avatar
Old Mar 26, 2008 | 07:42 PM
bboixtc's Avatar
No 1 really?
Old Mar 26, 2008 | 11:35 PM
snobordboy's Avatar
Moderator
Sounds odd to me, so dumb question, but are you facing the clutch disc the right way?
Old Mar 27, 2008 | 04:44 AM
bboixtc's Avatar
Default Re: (snobordboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snobordboi &raquo;</TD></TR><TR><TD CLASS="quote">Sounds odd to me, so dumb question, but are you facing the clutch disc the right way?</TD></TR></TABLE>
The clutch only fits one way. If I put it the other way, the springs on the clutch touch the flywheel bolts and it's not flush with the flywheel.
Old Mar 28, 2008 | 09:56 AM
bboixtc's Avatar
Default Re: (bboixtc)
Anyone???
Old Mar 28, 2008 | 11:49 AM
dre2day's Avatar
You sure its the right stuff for your car? Check with the ebay seller to make sure.
Old Mar 28, 2008 | 06:52 PM
yroachy's Avatar
Default Re: (dre2day)
check the exeddy website as well to make sure you ordered right... sucks if you didn't coz you'll have to go through a hassel sending it back and getting a new one!
B_Swapped93
Nov 17, 2013 08:42 PM
zerovandez
Mar 10, 2007 11:08 AM
escape2me
May 25, 2006 08:33 AM
LSVTEC408
May 21, 2005 01:05 PM
-[95cxhatch]-
Mar 1, 2004 01:22 PM
