New Build seems hard to crank over...
Old Mar 24, 2008 | 05:50 PM
jmac's Avatar
Default New Build seems hard to crank over...
The parts:
Stock LS Block
Stock LS Crank
Weisco pistons
Eagle LS rods
ACL bearings/Thrust Washers
Well I'm building a LS VTEC for my CRX and I have run into a potential problem:
- with all 4 rods/pistons connected (no head on) the crank is hard to turn over by hand at the very beginning of every crank attempt, then it seems to go smoothly after it has been started and has momentum. When you stop and leave it for a minute and try to another crank attempt it sticks for a second and takes quite a bit to get it to start moving then it goes ok.If I take the #4 rod off the crank spins freely, very smooth right from the get go. The Clearances were all within spec when I plastiguaged them. Everything was torqued to spec also.
(sorry if it's difficult to understand, it's hard to describe properly)
Will the "tightness" go away after a short break in? Or will it end up as a spun bearing? I was told it would be alright but I don't want to take any chances.
Any knowledgeable input is appreciated.
Old Mar 24, 2008 | 06:42 PM
stockb18c's Avatar
new rings bud i couldnt even turn mine with my hand had to wrench to turn its fine dont worry about it as long as you did the tq specs right your fine
Old Mar 25, 2008 | 05:46 PM
jmac's Avatar
Default Re: (stockb18c)
hmmm, yeah i was wondering about them also. I bought them slightly used off a friend so it's definetly possible.
I was hoping it would go away after i added the oil, but best not to risk it
Old Mar 25, 2008 | 06:07 PM
Maxcapacity's Avatar
Default Re: (jmac)
Mine felt the same way when i built my motor, I thought I messed up somewhere but 1 1/2 yrs with 14psi and still running like a champ.
Old Mar 26, 2008 | 11:04 AM
jmac's Avatar
Default Re: (Maxcapacity)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Maxcapacity &raquo;</TD></TR><TR><TD CLASS="quote">Mine felt the same way when i built my motor, I thought I messed up somewhere but 1 1/2 yrs with 14psi and still running like a champ. </TD></TR></TABLE>
That's what I was hoping for. Dang, decisions, decisions.
Gaspari
Sep 14, 2010 01:42 PM
jrscb16eg6
Aug 12, 2008 03:02 PM
BlakeJ53
Sep 4, 2007 03:59 AM
[Ennis_D]
May 14, 2007 02:34 PM
