Timing belt
Old Mar 24, 2008 | 05:18 AM
braass91's Avatar
Default Timing belt
I am doing this for the first time so I need some 411 and help.
Before I remove the engine mounting bolts, do I have to support the engine with a floorjack under the oil pan, according to Haynes? I have the Honda manual and it doesn't say anything about supporting the engine with a floorjack.
I'm having trouble removing the engine mounting bolts. Any advice?
Thanks
Old Mar 24, 2008 | 05:56 AM
~sp33~'s Avatar
EFB055
Supporting it on jacks may relieve some pressure off of the bolts making them easier to remove.
For some reason i managed to unbolt a bolt that had been welded on... Hadn't realised it needed to be undone from the OTHER side lol.
Old Mar 24, 2008 | 08:00 AM
braass91's Avatar
Default Re: (~sp33~)
I'm having trouble taking the 2 mounting bolts off. I'll have to use a steel bar for some leverage.
Old Mar 24, 2008 | 08:53 AM
misha's Avatar
Default Re: (braass91)
put the car on jack stands and support the engine by a floor jack with a piece of wood in between. Alos the jack will help you to get those bolts out.
Old Mar 24, 2008 | 10:18 AM
braass91's Avatar
Default Re: (misha)
Can I use a 2 Toyota LC cylinder jacks instead? How much pressure do you jackup the piece of wood under the oil pan? Just flush or a tad more?
JamesB1985
Dec 23, 2011 09:13 PM
stevenDAtegra
Dec 8, 2008 12:16 PM
Twistedframe
Oct 5, 2007 05:44 PM
sauceja
Jan 10, 2006 08:37 AM
sporkcrx
Jan 10, 2003 01:29 AM
