Cylinder Head Bolts
Old Dec 7, 2008 | 07:45 PM
stevenDAtegra's Avatar
Default Cylinder Head Bolts
I'm currently trying to take the head off my LS B18. I have my motor sitting on the ground and when I try to loosen the bolts the engine spins and the bolts seem REALLY tight. Even when I have someone hold the motor it'll spin.
Should they be this stuck on?
Old Dec 7, 2008 | 09:22 PM
SOHC_4dr's Avatar
they should be very tight but im not sure of your strength or anything so we cant tell how much force your really putting on it. if you have an impact use it. just replace the bolts. they cant be re-used
Old Dec 7, 2008 | 09:33 PM
EnjoyTheRideDC2's Avatar
Yes, they are that hard to break free. I would've suggested to loosen them with the engine still anchored in the engine bay to help hold the engine in place. I dont think you should use an impact unless absolutely necessary. To help get some leverage on loosening those bolts, use a breaker bar or use a pipe and slide it over your rachet handle so you can use more body strength and not rely on arm strength so much.
Old Dec 7, 2008 | 09:45 PM
Alright, thanks guys. I can probably get them off with my breaker bar but I wanted to make sure it was normal for them being that tight. I was weary that maybe I would end up breaking the studs
Old Dec 8, 2008 | 12:16 PM
You could still possibly break a stud, but thats impossible to predict. I wouldn't worry about that so much though.
dustin
Engine Machining & Assembly
27
Jan 10, 2018 11:41 PM
Tong.Y
32
Feb 1, 2011 02:05 PM
xiaogou
Apr 7, 2007 12:47 PM
InvaderTrax
Oct 6, 2006 06:28 AM
B96v6
May 31, 2002 05:25 PM
