Where is 2nd o2 sensor plug located?
Old Mar 24, 2008 | 02:29 AM
creepy116's Avatar
Default Where is 2nd o2 sensor plug located?
I need help finding the plug for the 2nd o2 sensor plug(the one connected to the cat) i have a 99 civic coupe
Old Mar 24, 2008 | 07:10 AM
LastGenEK's Avatar
Default Re: Where is 2nd o2 sensor plug located? (creepy116)
Its on the Cat, then the wires run up about where the shifter is.
Old Mar 24, 2008 | 12:01 PM
creepy116's Avatar
Default Re: Where is 2nd o2 sensor plug located? (LastGenEK)
Are you sure? i took off the cover for the shifter i can't find the wires
Old Mar 24, 2008 | 01:20 PM
1993-eg1's Avatar
there will be a rubber peace right above the cat where the o2 comes out pull this down then you will have to fight with the wires a bit and the plug will come down when you get it there u will have to move it a bit but it will fit throe the hole i will try to tack some pics to night and get back to you if you still need them
Old Mar 24, 2008 | 05:50 PM
creepy116's Avatar
Default Re: Where is 2nd o2 sensor plug located? (1993-eg1)
ok thx, ill try to pull that rubber piece out
Old Mar 24, 2008 | 06:22 PM
v8killaz's Avatar
don't do it from inside the car, get under and u will see it its impossible to miss
Old Mar 24, 2008 | 06:43 PM
creepy116's Avatar
Default Re: Where is 2nd o2 sensor plug located? (v8killaz)
thanks a lot guys! hopefully this is the problem with my check engine light
Old Mar 24, 2008 | 06:45 PM
Thateguhate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by creepy116 &raquo;</TD></TR><TR><TD CLASS="quote">thanks a lot guys! hopefully this is the problem with my check engine light</TD></TR></TABLE>
did you pull the code to make sure it is...? Check the code first before you bother doing all this.
Old Mar 24, 2008 | 06:48 PM
creepy116's Avatar
Default Re: Where is 2nd o2 sensor plug located? (Thateguhate)
i tried pulling the code, but it wouldn't let. i believe it is because i have jdm ecu.
Old Mar 24, 2008 | 07:52 PM
v8killaz's Avatar
dude ur 2nd o2 sensor has nothing to do with ur engine or much, its just their to chk if ur cat is working which I thnk u could care less, the code will come up and show it though, but no need to fix it since the main sensor is the main player, but its up to u if u want to chnge it, its really east anyways
RonCha
Dec 18, 2018 11:24 AM
Belarus
Mar 24, 2010 10:57 PM
amej8
May 28, 2008 02:34 PM
pregunta
May 30, 2003 09:35 AM
