what rods should i to go with crower or eagle???
Old Mar 23, 2008 | 07:15 PM
hondakid94's Avatar
Default what rods should i to go with crower or eagle???
im doing a low compression build on a gsr block and a built b16 head, trying to get 400hp. im using arias 9 to 1 pistons and i have both crower I beam rods and eagle H beams, im not too sure which ones to go with??? can i get some opions. thanks
Modified by hondakid94 at 9:07 PM 3/23/2008
Old Mar 23, 2008 | 07:20 PM
dbiker207's Avatar
Default Re: what rods should i to go with crower or eagle??? (hondakid94)
if you have both then i would use the crowers they are a better rod. that said both would work fine, as long as the eagles have the newer larger bolts
Old Mar 23, 2008 | 08:42 PM
blinx9900's Avatar
Default Re: what rods should i to go with crower or eagle??? (dbiker207)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dbiker207 &raquo;</TD></TR><TR><TD CLASS="quote">if you have both then i would use the crowers they are a better rod. that said both would work fine, as long as the eagles have the newer larger bolts</TD></TR></TABLE>
you sure crower I beams are stronger than eagle H beams? dont they advertise that as a mild boost mainly NA rod?
Old Mar 23, 2008 | 08:50 PM
quicksilver1689's Avatar
i ♥ snails
I-beams are generally lighter and made for high rpm use with no power adders, not always but alot of the time.
Old Mar 23, 2008 | 09:19 PM
dbiker207's Avatar
Default Re: (quicksilver1689)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 &raquo;</TD></TR><TR><TD CLASS="quote">
you sure crower I beams are stronger than eagle H beams? dont they advertise that as a mild boost mainly NA rod?</TD></TR></TABLE>
http://www.crower.com/cat/impo...shtml
if they are the 4340 billet rods they can handle all the power he can throw at it.
if they are the maxi light rods they are not as strong.
Old Mar 23, 2008 | 09:35 PM
blinx9900's Avatar
Default Re: (dbiker207)
if they are the maxi light rods they are not as strong.</TD></TR></TABLE>
oh snaps, i was only aware of the maxi light version, good info
Old Mar 23, 2008 | 09:48 PM
hondakid94's Avatar
thanks for the good info. the 4340 Steel Billet Connecting Rods are the same ones i have, so it loooks like i should go with the crower rods over the eagle's since i already have them.
Old Mar 23, 2008 | 10:28 PM
96 GSR-T's Avatar
I have the Crower Pro Billetts, used them in my last motor and this one, never had an issue.
Old Mar 24, 2008 | 03:56 AM
blackeg's Avatar
Default Re: (96 GSR-T)
use the eagles, they will handle 400hp no problem, and you can sell the crowers for more money than you could sell the eagles
Old Mar 24, 2008 | 04:26 AM
Mikey3000's Avatar
Default Re: (blackeg)
for 400 hp eagles will be fine. but i guarantee you're gonna want more power at some point so you might as well spend the extra $200 and get the better ones, crower.
Old Mar 24, 2008 | 09:22 AM
dr_latino999's Avatar
Default Re: (Mikey3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikey3000 &raquo;</TD></TR><TR><TD CLASS="quote">for 400 hp eagles will be fine. but i guarantee you're gonna want more power at some point so you might as well spend the extra $200 and get the better ones, crower.</TD></TR></TABLE> Extra 200? I've been quoted $280 for Eagles and yet I see the Crower Rods MSRP 726! Where do you get the Crower Rods for 500?
Old Mar 24, 2008 | 10:52 AM
LastGenEK's Avatar
Default Re: (dr_latino999)
I Use H-Beams....if i had the money id buy I-beams
Old Mar 24, 2008 | 10:56 AM
i ♥ snails
i think this is kinda going the wrong way, hes looking for 400whp, eagles will handle that no problem, he can save a few hundred bucks to spend on another aspect of the build, not saying anything bad about the crowers there quality pieces but for this specific application almost any aftermarket rod will do.
Old Mar 24, 2008 | 11:51 AM
The sweed's Avatar
Both rods will handle 400 hp. It´s not hp that kills rods it is rpm. So if you are reving to like 9000 eagles would be fine. If you wants to rev higher.. I would trust the crower billet ones better.
So if you are gonna rev to like 9000 and make 400 hp I would chuse the lightest rod.
Old Mar 24, 2008 | 03:33 PM
Mikey3000's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote"> Extra 200? I've been quoted $280 for Eagles and yet I see the Crower Rods MSRP 726! Where do you get the Crower Rods for 500?</TD></TR></TABLE>
damn i didn't realize eagles were so cheap. i also didn't realize crowers were so expensive... DAMN! i got my crowers back in the day for like $600.
Old Mar 25, 2008 | 07:35 AM
log1c's Avatar
damn i didn't realize eagles were so cheap. i also didn't realize crowers were so expensive... DAMN! i got my crowers back in the day for like $600.</TD></TR></TABLE>
prices go up....yay economy haha
Old Mar 26, 2008 | 06:09 PM
mlrmotorsports's Avatar
Default Re: (log1c)
Can you use the Eagle H beam rods on a high RPM 12:5.1 comp K20? Or are they to heavy and not made to spin that fast.
Tim_EG
Sep 28, 2012 01:49 PM
DuVaL rAcEr
22
Feb 15, 2007 07:52 PM
SIred91
May 15, 2006 09:03 AM
ssr_h22
May 20, 2004 11:31 AM
94B18B1Teg
Feb 10, 2004 11:03 AM
