HELP !! im throwin v-tec code
Old Mar 23, 2008 | 06:31 PM
fryguy190's Avatar
Default HELP !! im throwin v-tec code
ok i went to setup a v-tec light and when i went to tap into the wire i needed it quit working. so i threw up check engine code 22 witch is v-tec. so i unplugged the battery for like 15 min. and set it back up to stock. but its still throwing up the code.
what should i do?
Edit: o yea one more thing my V-tec wont work at all b/c of the code
thanks.
Old Mar 23, 2008 | 06:35 PM
97Ej6mike's Avatar
VTEC wont work because you put a dash in there, lol. (Its VTEC, not V-TEC)
Also, check the wiring to make sure everything is still connected properly. Sounds to me like you snipped a wire by accident, or your "VTEC light" is causing a short.
Old Mar 23, 2008 | 06:45 PM
fryguy190's Avatar
Default Re: (97Ej6mike)
well i completly unhooked the vtec light and my buddy said to make shure the wire wasnt pulled from the plug, and to push the pin into the plug. but still its not working... and the wire i cliped i reconected...
Old Mar 23, 2008 | 07:15 PM
civic_101's Avatar
Default Re: (fryguy190)
im not an expert but check the vtec if its leakin oil or something prolly and o-ring went bad
Old Mar 23, 2008 | 07:23 PM
fryguy190's Avatar
Default Re: (civic_101)
"slaps head"
i cliped a wire. nothing els... everything is connected how it should be.
Old Mar 23, 2008 | 07:27 PM
civic_101's Avatar
*applause* well go figure lol
Pr0ject93hb
Sep 14, 2007 09:50 AM
sk8phaze
Jul 28, 2003 07:44 PM
Eg6_JDM
Apr 26, 2002 10:27 AM
TurboBumblBee
Mar 2, 2002 08:14 PM
prjctCIVIC
Jul 7, 2001 09:50 PM
