extended studs....
Old Mar 23, 2008 | 03:34 PM
laocivic's Avatar
Default extended studs....
i know with the brakes on the car u use a axle puller to get the piece off with the studs...how bout if i dont have brakes on the car. i just want the studs out can i hammer the back where the axle goes in? i dont care if it brakes i just need the studs.
i need to take this part off...any ideas???? IT IS OFF THE CAR
Modified by laocivic at 10:04 PM 3/23/2008
Old Mar 23, 2008 | 06:12 PM
laocivic's Avatar
Default Re: extended studs.... (laocivic)
heard i can notch the piece right behind the stud so i can knock em out. can i do this them rotate to the next one?
Old Mar 23, 2008 | 06:53 PM
hard_boiled_EG's Avatar
sooo, you don't need the hub...just the stud? and you don't care if the hub or suspension breaks....then put some lug nuts on the stud to protect the thread and hammer away....
Old Mar 24, 2008 | 06:20 AM
laocivic's Avatar
Default Re: extended studs.... (hard_boiled_EG)
i did that but i gets stucks on the back...i dont care cuz these r on another set of brake and im putting them on my car
Old Mar 24, 2008 | 06:41 AM
Luserkid's Avatar
Use a slide hammer and pull the hub off. Then you could replace the studs with ease.
dc2woohoo
Aug 5, 2006 09:08 PM
Joey.
Jul 5, 2006 04:44 PM
beedoublejay
Suspension & Brakes
17
Mar 2, 2006 08:13 AM
AlizeVS
Oct 6, 2004 05:37 PM
Cro-Mag
Jan 16, 2003 09:22 PM
