99 LS needs help! blinking CEL: p304,
Old Mar 22, 2008 | 08:07 PM
gohonda's Avatar
Default 99 LS needs help! blinking CEL: p304,
cylinder 4 misire and also got some other... code for misfire or system ignition system.
i am going to put a new distributor cap, rotor, and spark plug wires in it tomorrrow morning and see if that fixes it.
In the meantime any other ideas?
Thanks
Old Mar 23, 2008 | 05:54 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: 99 LS needs help! blinking CEL: p304, (gohonda)
Low compression in cylinder 4 due to a bad valve adjustment or bad valves (compression test will check this)
Bad fuel injector
Bad ignition components
Old Mar 23, 2008 | 08:23 AM
gohonda's Avatar
Default Re: 99 LS needs help! blinking CEL: p304, (Dogginator)
so i need to get a compression test ?
Old Mar 23, 2008 | 09:07 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gohonda &raquo;</TD></TR><TR><TD CLASS="quote">so i need to get a compression test ?
I would. You can buy a cheap tester for about $30.
Old Mar 23, 2008 | 03:52 PM
gohonda's Avatar
how much does a test cost at a shop.. (rough estimates)
CLCrandall
Honda CR-V & Element
16
Dec 13, 2016 11:50 AM
stwokay
Aug 26, 2014 08:56 PM
zirac50
Mar 5, 2007 12:26 PM
SHystrdyGSRtdy
Sep 7, 2005 08:51 PM
boredracer408
Jul 5, 2004 07:29 PM
