suspension ?
Old Mar 22, 2008 | 03:09 PM
streetcartuner's Avatar
Default suspension ?
will EK suspension work on a del sol or EG
i want to know cuz i work at a junk yard and theirs a EK hatch with tokico d spec suspension and i want it
thanks in advance
Old Mar 22, 2008 | 03:27 PM
lluks_844's Avatar
Default Re: suspension ? (streetcartuner)
The fronts will work, if you use you top hats from your car, and i read that the rear shock wont fit over the control arm without modification, or the other way it will be too loose. I dont remember at the moment
Old Mar 22, 2008 | 04:55 PM
B18C5-EH2's Avatar
Former Moderator
Loved
The rear lower forks on the shock are more narrow on the EK.
You can use the EK rears, but you will need to grind/trim some metal away from the lower control arm bushing where the fork slides over it.
I am running EK Koni Yellows on my EG hatch and had to trim the rear LCA bushings, and they've been fine for over 4-5 years now this way.
Oh and the front shocks on an EK have no brake hose mounts, so you will need to use zip ties to secire the brake hoses to the shock bodies so that they don't rub against anything, namely the CV axles.
Old Mar 22, 2008 | 05:04 PM
Ej Girl's Avatar
everything (front struts and springs) but the rear struts not a bad deal to get suspension from the junkyard. all ull have to do is buy some rear struts so ull save alot of money.
Old Mar 22, 2008 | 07:45 PM
Default Re: suspension ? (Ej Girl)
no their still on the car so i get the struts and coilovers so ya
Old Mar 23, 2008 | 05:27 AM
B18C5-EH2's Avatar
Former Moderator
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ej Girl &raquo;</TD></TR><TR><TD CLASS="quote">everything (front struts and springs) but the rear struts not a bad deal to get suspension from the junkyard. all ull have to do is buy some rear struts so ull save alot of money.</TD></TR></TABLE>
Did you happen to miss my post right above yours?
THE REARS WORK FINE WITH MINIMAL MODIFICATION TO THE REAR LOWER CONTROL ARM BUSHINGS WHERE THE REAR SHOCK FORK SLIDES OVER THEM
Old Mar 23, 2008 | 07:04 AM
Default Re: suspension ? (B18C5-EH2)
hey stuip F*&K did u miss the post above EJ girl
i have to trim the rear trailing arm bushing
DUH cant u read so dont jump down my throat
Old Mar 23, 2008 | 02:14 PM
B18C5-EH2's Avatar
Former Moderator
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetcartuner &raquo;</TD></TR><TR><TD CLASS="quote">hey stuip F*&K did u miss the post above EJ girl
DUH cant u read so dont jump down my throat </TD></TR></TABLE>
Who are you talking to?
Old Mar 23, 2008 | 03:26 PM
ef8cybercrx's Avatar
I think he's talking to you. I wouldn't let him talk to you like that if I were you.
i have to trim the rear trailing arm bushing </TD></TR></TABLE>
It's not the Trailing Arm bushing you have to trim but the Control Arm bushing
Old Mar 23, 2008 | 07:06 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: suspension ? (ef8cybercrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef8cybercrx &raquo;</TD></TR><TR><TD CLASS="quote"> I think he's talking to you. I wouldn't let him talk to you like that if I were you.
It's not the Trailing Arm bushing you have to trim but the Control Arm bushing</TD></TR></TABLE>
Well I feel sorry for the guy if he was talking to me.
1. I posted the most helpful info including exactly what the differences were, and how to fix them
2. I directly quoted Ej girl and asked her why she was posting "it won't work" when my own post above hers told exactly how it does work
3. If he was really posting that directed towards me then he's probably mildy to full-blown retarded seeing as how he's trying to tell me I missed my own fuucking post
4. Also he did in fact say "trailing arm bushing" after I had told him rear lower control arm busing, where the rear shock fork slides over it. I thought I made that pretty clear.
Modified by B18C5-EH2 at 11:13 PM 3/23/2008
tougetuned_ef
Suspension & Brakes
Jun 1, 2010 03:15 PM
emooheo
Suspension & Brakes
Jul 7, 2009 07:02 PM
PHATFLIP
Jul 1, 2007 05:07 PM
skoolz4loserz
Suspension & Brakes
10
Nov 3, 2005 06:04 PM
BeavisB16
Aug 18, 2004 03:20 AM
