EK struts on EG?
Re: EK struts on EG? (BeavisB16)
I will but you would have to chisel off the brake line brackets from your old struts and slap them on the ek struts.(or you can always zip tie them)
the fronts will fit fine but the rear ek struts are more narrow at the fork part. I had to use ek struts on my hatch before, the only way the rears will fit is if you shave the rear lower control arm bushing besides that everything else bolts up the same
Re: (Vp Special K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vp Special K »</TD></TR><TR><TD CLASS="quote">the fronts will fit fine but the rear ek struts are more narrow at the fork part. I had to use ek struts on my hatch before, the only way the rears will fit is if you shave the rear lower control arm bushing besides that everything else bolts up the same</TD></TR></TABLE>
What tool did you use to shave/cut off the extra bushing part? Im in the process of putting my ek koni yellows on my eg. Thanks, let me know.
infamousALLMTR
01-02-2003 10:56 AM
