Faulty VTEC Engagement...Ideas?
Old Mar 22, 2008 | 02:32 PM
XSIintegra's Avatar
Default Faulty VTEC Engagement...Ideas?
When VTEC engages, the engine shudders and has a very hard time accelerating.
Figuring it was a possible tune issue, I engaged the solenoid manually at 4k.
The engine immediately starts a dive in RPMs till it stalls to its death. The engine sounds good. The oil pressure is good. The Solenoid is engaging.
This is a fresh rebuild. The head was picked up off of Ebay. The rails and assembly are from my previous B16 that blew. They were used so that everything came off and went on in the exact order is should.
I can not figure out what is mechanically wrong with the setup. Almost as if one cam is engaging and the other is not.
Any ideas?
B16A1/B18C1
Full SK2 Valves, Springs, Retainers
Blox Stage 2 Cams
SK2 Gears
70lbs plus/minus When VTEC is engaged.
Thanks
Old Mar 22, 2008 | 02:39 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Faulty VTEC Engagement...Ideas? (XSIintegra)
ECU tune? Knock sensor?
Old Mar 22, 2008 | 03:04 PM
beatthisspeed69's Avatar
have you tried cleaning or changing out the oil sensor thing next to the vtec soilinoid i cant think of the name right now
Old Mar 22, 2008 | 03:07 PM
XSIintegra's Avatar
Default Re: (beatthisspeed69)
I thought it may be a tune, but I should still be able to engage VTEC manually. It should sound a bit odd and make no real power, but still run.
I have no Knock Sensor or Oil Sensor feedback.
Running an AEM EMS...it could care less
Even my tune logs didn't look to bad. Should have at least engaged and ran.
Pretty sure its a mechanical ghost of some sort...♠
silverteggy94
Jul 21, 2013 06:59 PM
95b16civic
Mar 16, 2010 09:04 PM
gshatch
Jun 21, 2008 11:35 AM
bey
Nov 27, 2002 09:06 PM
r7
12
Jun 13, 2002 10:21 AM
