Suspension & Brakes Theory, alignment, spring rates....
Anti seize where the ball joint goes in the knuckle? answers ASAP!!!
Old Mar 22, 2008 | 12:36 PM
civicdelsol33's Avatar
Default Anti seize where the ball joint goes in the knuckle? answers ASAP!!!
Okay Im getting ready to hammer back in my LBJ, and was curious. Should I put any anti seize on where the ball joint is presed into the knuckle? I dont have alot of time to let the LBJ sit in the freezer. I will let it sit like 30 mins max then heat up the knuckle with a torch.
Im just trying to get it to go in easier. Last time I almost lost my thumb and I ruined the LBJ. Well one side at least. I got the other side to work
If anyone could answer in the next 30 minutes that would be great.
Old Mar 22, 2008 | 01:46 PM
hayabusa160's Avatar
Default Re: Anti seize where the ball joint goes in the knuckle? answers ASAP!!! (civicdelsol33)
wd40 works. you dont have to use antisieze might make it harder to go in its pretty thick.
Skelly
Aug 25, 2006 03:54 PM
95dxhatch
Mar 7, 2004 09:18 PM
Wo-Nelly
Mar 3, 2004 03:27 PM
ilikemyaccord
Aug 29, 2003 01:25 PM
wusta515
Sep 15, 2001 03:48 PM
