Steering seems very LOOSE...
Old Mar 21, 2008 | 10:18 PM
steadysupreme's Avatar
Default Steering seems very LOOSE...
My steering seems very light. What i am saying is, I turn a lot on the steering wheel but the car doesn't turn much. I don't know how to describe it, maybe it is not responsive???
Anyone had this problem before?
Because i just got my other type R friend to test drive it, he said it is definitely looser than his steering.
Old Mar 21, 2008 | 10:59 PM
beat's Avatar
Default Re: Steering seems very LOOSE... (steadysupreme)
If you turn a lot on the steering wheel, but your wheel doesnt really turn as much, then its not your steering wheel being loose. That has to do with steering ratio.
If its just your steering wheel being lose, then check your tire pressure
Old Mar 22, 2008 | 12:27 AM
Default Re: Steering seems very LOOSE... (beat)
haha...i didn't mean that my steering wheel is loose.
Let me try to re-word myself.
I got the loose feeling from the steering wheel, i might suspect something being loose on the steering components. rack?? I really don't know.
Also, let's day, pushing in 1st gear going all the way to redline and change to 2nd. Will you guys feel that the steering wheel pulls/jerks to one side?
Old Mar 22, 2008 | 12:29 AM
Actually i did mention about being turning a lot on the steering wheel and wheel doesn't turn much. Do you guys feel the same? I mean i just don't have that SOLID feeling.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beat &raquo;</TD></TR><TR><TD CLASS="quote">If you turn a lot on the steering wheel, but your wheel doesnt really turn as much, then its not your steering wheel being loose. That has to do with steering ratio.</TD></TR></TABLE>
Old Mar 22, 2008 | 03:50 AM
citrus3000psi's Avatar
What type of tires are you running? including tire size, rim size, tire pressure.
Old Mar 22, 2008 | 04:57 AM
an2ny888's Avatar
when's the last time you replaced your tie rods? they could be worn out
Old Mar 22, 2008 | 07:07 AM
AW's Avatar
AW
How many miles on the car. Something that wears out is the actual steering rack. You will get this off center feel from the steering where the wheel does not feel on center or loose.
Old Mar 22, 2008 | 01:37 PM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: Steering seems very LOOSE... (AW)
I actually had something very similar to this happen. What it wound up being: someone tried to steal my car, and I guess in trying to break the steering column lock by jerking the steering wheel, they actually stripped the splines off the inside of the steering wheel. So the steering wheel turned a lot, but the wheels didn't actually move. This may or may not have been from previous abuse to the splines, I don't know. I DO know there was a theft attempt on my car just prior to that happening. Pulling the steering wheel is fairly easy, so you might want to check there. Just make sure you disconnect the battery and airbag first
Old Mar 22, 2008 | 07:26 PM
RagingAngel's Avatar
If its just your steering wheel being lose, then check your tire pressure</TD></TR></TABLE>
Funny that you even drive a Type-R because the steering ratio itself is relatively quick for a car of its era/spec - that most people find it acceptable. The OP even said he had a direct comparison with another friend's Type-R.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steadysupreme &raquo;</TD></TR><TR><TD CLASS="quote">Actually i did mention about being turning a lot on the steering wheel and wheel doesn't turn much. Do you guys feel the same? I mean i just don't have that SOLID feeling.
Your steering rack might need adjustment:
https://honda-tech.com/zerothread?id=569090
Old Mar 23, 2008 | 02:40 AM
Default Re: Steering seems very LOOSE... (RagingAngel)
Thx very much for the link, i will definitely try this out~
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RagingAngel &raquo;</TD></TR><TR><TD CLASS="quote">
Old Mar 23, 2008 | 02:45 AM
Default Re: Steering seems very LOOSE... (Stinkycheezmonky)
And yes the car had 120,000km right now, so about 75,000miles on it and it had a theft claim before.
So how did you fix your problem? Get a new steering column?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stinkycheezmonky &raquo;</TD></TR><TR><TD CLASS="quote">I actually had something very similar to this happen. What it wound up being: someone tried to steal my car, and I guess in trying to break the steering column lock by jerking the steering wheel, they actually stripped the splines off the inside of the steering wheel. So the steering wheel turned a lot, but the wheels didn't actually move. This may or may not have been from previous abuse to the splines, I don't know. I DO know there was a theft attempt on my car just prior to that happening. Pulling the steering wheel is fairly easy, so you might want to check there. Just make sure you disconnect the battery and airbag first </TD></TR></TABLE>
Old Mar 23, 2008 | 01:04 PM
Suspetise...
The column was fine, it was the steering wheel splines that got stripped. Solution: new steering wheel.
Ur 2 Slow 4 J
Nov 1, 2015 02:25 PM
niceprelude
Jan 30, 2009 07:50 AM
VTEC-LUDE
Jan 7, 2007 06:42 AM
