swap b20 automatic really need help eg 93 civic tcm
Old Mar 21, 2008 | 08:16 PM
incognitob20eg's Avatar
Default swap b20 automatic really need help eg 93 civic tcm
i have a 93 civic hatch and i am going to leave it AUTO but here is the fun part i have a b20b that i am dying to put in there i have all the parts and i really need help on the wiring thing here
i kept my stock ecu which i am told is ok as long as i run a fuel pressure regulator on it and then for the tranny i have a auto gsr tranny straight from japan yes a auto gsr lol but i have a problem i have a tcm...
transmission control module ...
from a 95 integ auto but i have no idea how to wire it up to the stock ecu if i do not use a tcm then when i turn the car on in park it starts to spin the tires can you help me out with anything here
Old Mar 22, 2008 | 03:22 AM
Deetz's Avatar
Crazy Honda Guy
Default Re: swap b20 automatic really need help eg 93 civic tcm (incognitob20eg)
For the trouble, i would swap over to a 5speed, but your choice. I can tell you right now, that the stock ecu would most definitely not work well with that setup unless chipped and programmed accordingly with some decent time at the dyno only after you have finished all the rest of what ever swap you decide to run.
incognitob20eg
Welding / Fabrication
Mar 23, 2008 03:19 PM
incognitob20eg
Mar 15, 2008 05:35 PM
voodoodaddy
Mar 13, 2008 05:56 PM
hybrid_KJ
Jan 17, 2003 05:35 AM
