Need help with smog! It barely fails!
Old Mar 21, 2008 | 12:44 PM
SlimDC5's Avatar
Default Need help with smog! It barely fails!
I took my gf's 90 Integra to get smogged today. Didn't pass, Kind of wondering on what it could be. Here are my numbers:
15MPH:
HC:
Max: 121
Meas:48
CO:
Max: .76
Meas: .21
NO:
Max: 807
Meas: 899
25 MPH
HC:
Max:96
Meas:39
CO:
Max: .65
Meas: .22
NO:
Max: 746
Meas: 723
So as you can see it barely fails. If anybody has any input I would greatly appreciate it. Thx in advance
Old Mar 21, 2008 | 02:12 PM
fasteddy91's Avatar
Default Re: Need help with smog! It barely fails! (SlimDC5)
get a new cat
Old Mar 21, 2008 | 02:15 PM
99Geeezer's Avatar
check for vaccum leaks. High nox means your mixture is too lean. make sure timing is set properly as well.
Old Mar 21, 2008 | 05:18 PM
SlimDC5's Avatar
Default Re: Need help with smog! It barely fails! (fasteddy91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fasteddy91 &raquo;</TD></TR><TR><TD CLASS="quote">get a new cat</TD></TR></TABLE>Pretty much what i've been thinking along w/ a new o2 sensor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99Geeezer &raquo;</TD></TR><TR><TD CLASS="quote">check for vaccum leaks. High nox means your mixture is too lean. make sure timing is set properly as well.</TD></TR></TABLE>Timing is dead on, I'll see about the vacum leaks.
Would a new pcv valve help as well???
And thank you for your responses
Old Mar 21, 2008 | 05:52 PM
jay_cue's Avatar
with failing by that little, you shouldnt have to replace your cat, especially since the only part you failed was nox at 15
Old Mar 21, 2008 | 05:56 PM
SlimDC5's Avatar
Default Re: Need help with smog! It barely fails! (jay_cue)
So it might be something small??
Old Mar 22, 2008 | 01:11 PM
SlimDC5's Avatar
bump for more info
Old Mar 22, 2008 | 10:56 PM
BKKloppenborg's Avatar
I just smoged mine today. Things to keep a eye on before testing (What i do)
1. Tune up (Plugs, Wires, Cap, etc)
2. Check O2 sensors, and cat life
3.PCV value could be the probelm (take it off Shake it and if you hear a sound its ok, if not its bad)
4. I use Lucas in my Tank to keep it clean.
Old Mar 23, 2008 | 05:46 AM
SlimDC5's Avatar
Default Re: Need help with smog! It barely fails! (BKKloppenborg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BKKloppenborg &raquo;</TD></TR><TR><TD CLASS="quote">I just smoged mine today. Things to keep a eye on before testing (What i do)
4. I use Lucas in my Tank to keep it clean.</TD></TR></TABLE>Yeah pretty much what I'm going to do when I take it back, As far as the cat, Is there a way to tell that it's bad???
Old Apr 21, 2008 | 01:34 PM
FTP racing's Avatar
I'd use a higher octane fuel that should do it....
Old Apr 21, 2008 | 09:07 PM
JETSPD1477's Avatar
high nox is a lean mixture usually. high combustion chamber temps in general.
1. try advancing timing to around 15 deg btdc.. which is still withing the acceptable limits
2. check fuel filter/pressure
3. check coolant... try mixing closer to the water side.
4. higher octane fuel since it burns slower and help cool cumbustion chamber (mentioned earlier)
5. Test O2 sensor. maybe just replace it since it isn't heated and will be cheap.
6. go to your local parts store and look for a product called "HEET" its a fuel anti-freeze. throw a bottle in at half tank and drive around for a few miles.
this is all i can think of for right now... high NOX is common but not impossible to remidy.
Old Apr 21, 2008 | 09:27 PM
SlimDC5's Avatar
Default Re: (JETSPD1477)
Thanks bro, i'll look into that
Old Apr 21, 2008 | 09:43 PM
Tarmac Junkie's Avatar
Default Re: (SlimDC5)
Before going to smog, drive around for 20 minutes or so to get the cat hot. Also what was mentioned above...
Old Apr 21, 2008 | 09:57 PM
1998_4dr_gsr's Avatar
Default Re: (Tarmac Junkie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tarmac Junkie &raquo;</TD></TR><TR><TD CLASS="quote">Before going to smog, drive around for 20 minutes or so to get the cat hot. Also what was mentioned above...</TD></TR></TABLE>
I second that! Drive it for awhile and get your engine super hot (cat also). Also, each visit can vary in measuring NO or HC. Maybe next time you go you'll pass witout having to do much. Good luck
Old Apr 24, 2008 | 12:34 PM
FTP racing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JETSPD1477 &raquo;</TD></TR><TR><TD CLASS="quote">high nox is a lean mixture usually. high combustion chamber temps in general.
Please help me understand how advancing the timing is gonna bring down nox?
Old Apr 24, 2008 | 01:58 PM
JETSPD1477's Avatar
Default Re: (FTP racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FTP racing &raquo;</TD></TR><TR><TD CLASS="quote">
Please help me understand how advancing the timing is gonna bring down nox?</TD></TR></TABLE>
my mistake. i meant retarding...
Old Apr 25, 2008 | 08:37 AM
FTP racing's Avatar
no worries!
Old Apr 25, 2008 | 08:53 AM
steveteggy92's Avatar
There's some stuff at your local auto parts store called Guaranteed To Pass (GTP)
It works~
rodvang
20
Oct 2, 2007 10:58 AM
JThrasher79
Mar 10, 2007 01:49 PM
Danziver
Sep 5, 2006 07:06 PM
mintscorpion
19
Jan 20, 2006 04:27 PM
sohc90rex
16
Mar 31, 2005 07:27 PM
