car just shuts off.
its happened a couple times, when i come to a stoplight it turns off, all power is still on just the motor shuts off. its done it twice this week. never happened before, it starts right up after about ten secs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Midori Green »</TD></TR><TR><TD CLASS="quote">most likely your distributor is bad just take it to a mechanic to get checked</TD></TR></TABLE>
??.... it could be a million things
what is your idle doing? give some more details what happened before it shut off...
sounds like a ignition switch, has it ever happen while your driving, and if so can you just turn the key and it starts right back up ( when in gear), cause if that happens then its your ignition switch ( when i say ignition switch i mean the thing you put your key into to start you car)
M2B4
Feb 20, 2010 08:57 PM
wizzards581
12
Dec 11, 2003 06:25 PM
