need Help With car to pass emissions
Old Mar 21, 2008 | 09:51 AM
limegreencivichb's Avatar
Default need Help With car to pass emissions
I have a 89 civic hb with a shoc ZC Swap I have read the computer and i get the following codes need to know if i got a bad throttle body from the wreckers.
16- Fuel Injector Circuit
07- Throttle angle Sensor or Circuit
10-Intake Air Themperature Sensor or Circuit
14- Electronic Air Control Valve
Replaced all the plugs and wires and even the O2 sensor with all NGK parts Can someone please help me.. Thank-you
Old Mar 21, 2008 | 11:06 AM
thesmogman's Avatar
Default Re: need Help With car to pass emissions (limegreencivichb)
Sounds like the swap has gone bad..
You have to start on one and then the other.
TPS Need adjusted or repl. check voltage
IAC just replace or check resistance
EACV clean and check resistance
Injectors also check resistance.
So there is a start. Hope you have a voltmeter.
airikkCRX
Apr 25, 2010 11:23 AM
si del sol 94
18
Sep 16, 2009 07:39 PM
PhanatNy
Jan 31, 2009 12:01 PM
x91crxsix
May 20, 2008 09:04 AM
turbob16ef
Mar 13, 2006 12:58 PM
