another honda wont start
Old Mar 21, 2008 | 09:17 AM
f22kid's Avatar
Default another honda wont start
okay here it goes last wednesday i was working dewlivering food went through the whole night ran great. got up thursday morning to bring my pregnant g/f to the dr.'s and car wont start usually my luck its allways something bad so this time i checked the timing it seemed a tooth off and belt was really loose not to mention belt was soaked in oil because cam seal so i replaced the seal the balance shaft belt and the timing belt, cleaned everything up put it back together started but ran like real crap so i checked the timing again it was okay but went trhough the whole process again so timing was okay started but ran like crap so my friend said hey pull the plugs and see what they look like maybe preignition or something pulled them and cyl 2 and 4 were fried the electrodes were gone so then i replaced them car purred like a kitten ran good for two days delivered wednesday come out to go to the dr.'s thursday car wont start again..... im getting spark not real strong spark (spark is kind of red) with blue tint check the timing again it is fine im getting gas i pulled the test port and holy did it spray it fires likke every other revolution spits once then nothing i am clueless as to where to go now i know the distributor has been replaced before and the wires and plugs are new the only thing i havnt replaced yet was the rotor and cap im going to try that but i dont think its this can someone please help my girlfriends is due soon and i need this car to make money and now im t a stand still
Old Mar 21, 2008 | 09:30 AM
Mr Yamada's Avatar
Default Re: another honda wont start (f22kid)
From the description of the problem, weak spark indicates a coil that is shorting out.
Perhaps if you were willing to disclose the year and model of the Accord others may be better able to help you.
Old Mar 21, 2008 | 10:16 AM
f22kid's Avatar
Default Re: another honda wont start (Mr Yamada)
my car is a 1992 honda accord lx f22a1 4at coupe
Old Mar 21, 2008 | 12:30 PM
f22kid's Avatar
i was told it could be my coil so i checked it according to my haynes manual and it failed primary resistance test but another ase cert guy told me because resistance wasnt there i might have fried something else so im going ot pull the dist and have it checked piece by piece ill let everyone know what i find
Old Mar 21, 2008 | 05:41 PM
808S2000's Avatar
I do remember that year accord have a dist. update. I think the part # for that dist was
06301-PT3-A20
Old Jul 17, 2009 | 09:30 AM
firefighter2461's Avatar
New User
Try checking your main relay. Located high under the dash. I have a 92 Accord EX and I had the same problem. So frustrating! I tested the ignitor coil and it ohmed bad (replaced it). All other starting components were fine. But when I started reading other forums about the main relay over and over again I decided to make the effort!! Was well worth it!! Click the URL at the bottom of my reply it'll walk you through all the steps! Also, I took a large magnifying glass and you could see the cracks at the solder joints! Just look REALLY close at each joint and all around it as it is hard to see with the naked eye! I almost missed a cracked joint. Have had zero problems since the fix! Hope it works out for you!!http://techauto.te.funpic.org/mainrelaydefine.php
Old Jul 17, 2009 | 09:47 AM
GhostAccord's Avatar
This is the 5th "car won't start thread" you have posted this in. All of which have been at least a year old. Is this some sort of spam for that DIY or are you just overly horny to help. It's good that you were able to do a search for an old main relay DIY and fix your car?
Please check for dates before posting replies to 2 year old threads. I don't even think f22kid uses this forum any more.
ddn1313
Aug 4, 2018 02:46 PM
lavtxa
Honda Civic (2001 - 2005)
Jun 28, 2012 09:51 AM
d4ng3rb0y
15
Nov 24, 2009 08:15 AM
Jack Shephard
12
Feb 13, 2009 06:27 PM
specv5150
11
Oct 7, 2004 02:39 PM
