ABS ring on axle (same between different years?)
I did a h22 engine swap into my integra gsr. I had to use 89 integra axles that dont come with abs.My integra does have abs but without the abs ring on the axle the abs dosnt work.
Now my question is im pretty sure i can take off the abs ring off my stock axles but would it fit the 89 integra axle? is the outter cv joint the same size
also does anyone know if all honda abs rings are the same. i dont have my stock dc2 abs rings
