Rolling fenders...
Old Mar 21, 2008 | 05:23 AM
1slwEK's Avatar
Default Rolling fenders...
Wasn't sure if here or suspension was most appropriate, but I guess I would give this section a shot.
Basically I have a 99 coupe, decently lowered on some coilovers. Put on my front and rear camber kits yesterday. Well obviously if I kept the ride height the same and adjusted the camber properly there would be some rubbing issues when the suspension compresses over small grades turns. It's not a bad consistant rub, but it's there if you come in or out a corner to fast (or at all so far). I can see where the underneath of the fender is coming in contact, it's only about a foot long. What is the best way to roll the fender (along that part)?
Any pictures would be helpful!
Thanks,
Brandon
Old Mar 21, 2008 | 08:36 AM
Firstchild's Avatar
Default Re: Rolling fenders... (1slwEK)
shove a base ball bat between your fender and tire, roll the bat back and forth,
it will give you a clean bend, it sounds crazy but it is a cheap way of rolling fenders.
Old Mar 21, 2008 | 08:42 AM
dbiker207's Avatar
Default Re: Rolling fenders... (Firstchild)
i did mine with a hammer and some finesse, it chiped the paint in the fener well but i just covered it with some red spray paint. the paint on the outside of the car didnt chip at all.
i tried the baseball bat and i couldnt get it to do anything but put big gouges in the bats handle.
Old Mar 21, 2008 | 08:57 AM
hypeR_ash's Avatar
too LEGIT to quit
Default Re: Rolling fenders... (dbiker207)
http://www.team-integra.net/se...D=698
article how-to with a baseball bat. only thing they didnt do was use a heat gun to keep the paint from chipping.. not sure if thats needed but its probably an extra precaution.
Old Mar 21, 2008 | 09:59 AM
1slwEK's Avatar
Default Re: Rolling fenders... (hypeR_ash)
Thanks Ashley.
Old Mar 21, 2008 | 07:52 PM
toyomatt84's Avatar
Sanji
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hypeR_ash &raquo;</TD></TR><TR><TD CLASS="quote">http://www.team-integra.net/se...D=698
article how-to with a baseball bat. only thing they didnt do was use a heat gun to keep the paint from chipping.. not sure if thats needed but its probably an extra precaution.</TD></TR></TABLE>
It's highly recommended to run a heat gun, and get the paint quite warm. Otherwise, you'll see tons of cracking.
Old Mar 22, 2008 | 11:56 AM
1slwEK's Avatar
Default Re: Rolling fenders... (toyomatt84)
I performed the "bat method" yesterday. Worked reall well with a heat gun. had one small chip on the inside of tder that i just hit up with some touch up paint!
Old Mar 23, 2008 | 03:16 PM
turbo sol's Avatar
be careful, and def use a heat gun. I got the eastwood fender roller and it worked pretty good, assuming you don't have rusty lips on your fenders.
good luck.
Old Mar 23, 2008 | 04:10 PM
1slwEK's Avatar
Default Re: Rolling fenders... (turbo sol)
Thanks a lot. I rolled the fenders two days ago, heating the area I was working with for about 3 good minutes. Since I have such low miles on my car, there isn't any rust spots. I got one small crack on the inside of the fender (which you cannot even see without your head in the fender), and touched it up with some touch up paint.
Tire Rack has a pretty stout looking fender roller for $260. No a bad price, for such a quality looking piece.
Old Mar 23, 2008 | 04:36 PM
Evile140's Avatar
If you are a DIY'er
http://forums.vwvortex.com/zer...age=1
Old Mar 25, 2008 | 06:55 AM
jmm96gsr's Avatar
Default Re: (Evile140)
For anyone that will search this thread later, PM rice4life on here, he has a fender roller and heat gun that he rents out pretty cheap. He is located in Carlisle PA - I think it's an Eastwood.
Old Mar 25, 2008 | 07:52 PM
anomoly553's Avatar
Default Re: (jmm96gsr)
i saw a writeup in hotrod mag probly 5 years ago, they just stuck an angle grinder in there and cut the "rolled" part or the inside part about every inch or so, then folded it up so it laid flat against the outside panel
Old Mar 26, 2008 | 10:54 AM
1slwEK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmm96gsr &raquo;</TD></TR><TR><TD CLASS="quote">For anyone that will search this thread later, PM rice4life on here, he has a fender roller and heat gun that he rents out pretty cheap. He is located in Carlisle PA - I think it's an Eastwood. </TD></TR></TABLE>
DAMN!!! I wish I knew! Where were you a couple days ago!? Haha
Old Mar 26, 2008 | 01:54 PM
turbo sol's Avatar
Default Re: (1slwEK)
hell. I'll sell my eastwood to someone if they want it. only used once.
Old Mar 26, 2008 | 06:53 PM
jeffy's Avatar
Default Re: (turbo sol)
baseball bat
you gotta use the bat part though, not the handle.
did it on my old hatch, getting ready to do it on my db. spending money on stuff that isnt power or handling aint for me
Old Mar 27, 2008 | 12:33 PM
1slwEK's Avatar
Default Re: (jeffy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeffy &raquo;</TD></TR><TR><TD CLASS="quote">baseball bat
did it on my old hatch, getting ready to do it on my db. spending money on stuff that isnt power or handling aint for me </TD></TR></TABLE>
Hahahaha well put.
Old Apr 2, 2008 | 08:36 AM
JonLZG's Avatar
to this thread!
slow_low_eddie
Paint and Body
May 9, 2014 07:13 PM
dgerej2
Nov 23, 2009 08:36 PM
00civicsiboy
Suspension & Brakes
Feb 11, 2008 03:44 PM
pinoy2o9
May 21, 2007 03:18 PM
Stu
Sep 18, 2001 10:23 PM
