fpr making loud noise
Old Mar 21, 2008 | 05:01 AM
el_toro_de_magnifico's Avatar
Default fpr making loud noise
my stock fpr is making loud spraying like noise but the sound is not continuous. its like tsssst.....tst...tst..tsttst....tssssssst..... haha thats the best i could describe the sound. it sounds like someone just randomly messing around spraying spraypaint.
my car runs rich as hell and the injectors are fine i tested em. how could i tell if the fpr is f*cked? got really bad gas mileage and really bad idle sometimes going really low like it wants to die out, im thinking inconsistent fuel pressure. inputs would be much appreciated
Old Mar 22, 2008 | 09:19 PM
Default Re: fpr making loud noise (el_toro_de_magnifico)
up!
in addition to that, the idle is low and sometimes goes near zero but after i run the car hard going up to vtec and then letting it idle it idles like a champ then after a few seconds it idles real bad. what could this be? a little help ht
Old Mar 22, 2008 | 09:26 PM
grandtheftlunchbox's Avatar
pull the vacuum hose off your FPR, see if the inside of the hose is drenched with fuel. if it is, you have a leak in your FPR diaphragm and it needs to be replaced.
Old Mar 22, 2008 | 10:10 PM
afstvx's Avatar
x2 for bad diaphram
Old Mar 23, 2008 | 04:20 PM
Default Re: (afstvx)
ok! will check it this afternoon.
BakerIsBored
Honda Civic (2006 - 2015)
Nov 14, 2010 11:32 AM
AnAccordIsForever
Jul 13, 2006 11:52 AM
Sketch_hs
Jul 1, 2003 08:57 PM
MaxPowerIntegra
Jul 29, 2001 01:00 PM
