How To: JDM Dizzy Swap From USDM
Old Mar 20, 2008 | 06:08 PM
Acidcrakker's Avatar
Default How To: JDM Dizzy Swap From USDM
Its really quiet simple. I thought Id share it with all you guys here.
For one the purpose of this is to help eliminate the extra clutter Honda includes in the Engine Bay.
Here is a pic of how to wire the USDM Coil Harness.
Its quiet simple and anyone can do it.
And here is a video to explain the mechanics of how its done.
Video
All done by me and open to the public. Im pretty sure I covered it all in the Pic and Vid.
If you still dont understand dont hesitate to ask.
Modified by Acidcrakker at 11:30 AM 3/21/2008
Old Mar 20, 2008 | 06:47 PM
Default Re: How To: JDM Dizzy Swap From USDM (Acidcrakker)
Heres a vid, my camera sucks, they end
Clicky For VID
Old Mar 20, 2008 | 06:52 PM
AdReNaLiN's Avatar
Yes you can use the USDM rotor. Should fit right on just like you took it off...
As far as wiring goes, you need to bridge 2 of the 3 wires on the plug that goes to the external coil to make it work. You'll understand which ones I mean when you take a look at the wiring diagram.
I had an issue when I did the swap. I managed to blow 4 dizzy's in the space of about 6 months. Never really worked out the problem as I went to an MDI setup.
Old Mar 20, 2008 | 07:00 PM
Default Re: (AdReNaLiN)
Thanks thats what I figured, Just looking for extra imput on that. Im painting it right now, and it should be ready for installation in the morning.
I hope I dont go blowing 4 dizzys in 6 months.
Just curious what part of the dizzy did you blow?
Old Mar 20, 2008 | 07:29 PM
AdReNaLiN's Avatar
I'm not sure exactly. It was either the coil or the ignition control module.
Old Mar 20, 2008 | 08:06 PM
socialistic's Avatar
The 2 wires on the external coil plug from the engine harness that need to be bridged are yellow/black and yellow. Blue stays unused.
Either wire in a fuse between them, or stick a fuse directly into the plug and tape it off to protect it. I use a 20A fuse in mine.
Old Mar 21, 2008 | 06:11 AM
AdReNaLiN's Avatar
I used a fuse also.
Did you have any issues with distributors burning out?
Old Mar 21, 2008 | 06:46 AM
Well that is a fail. Does anyone know how to test the Coil on the JDM Dizzy, or where to get one?
Im about to swap out the igniter from Dizzys.
Old Mar 21, 2008 | 10:44 AM
I'm still finishing up this swap, only started the car once...so I wouldn't be able to tell you from experience if you'll burn through coils by doing this.
From what I've seen though, it's not a very common problem.
Old Mar 21, 2008 | 07:35 PM
Default Re: (socialistic)
Hey guys I have a question, can you use USDM parts on a JDM Distributor?
My Coil and ignigter is bad on my new distributor
Old Mar 21, 2008 | 09:10 PM
AdReNaLiN's Avatar
if the coil is bad on your jdm dizzy you're gonna have to get a new JDM coil or a whole new dizzy.
Old Mar 21, 2008 | 10:26 PM
I'd take that ignition module to a local autozone for testing, it's probably just a bad coil.
I wouldn't recommend mixing distributor components, just buy new so you have a warranty and some peace of mind. 8)
Old Mar 22, 2008 | 06:28 AM
Okay thanks, I found them on that site you sent me and on Ebay. Thanks for the help<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AdReNaLiN &raquo;</TD></TR><TR><TD CLASS="quote">if the coil is bad on your jdm dizzy you're gonna have to get a new JDM coil or a whole new dizzy.
Seto-Initial-B
Jul 6, 2006 03:33 PM
PIntegraMP
Apr 9, 2006 02:25 PM
b16crx0062004
Sep 22, 2004 07:25 PM
EF-9SiR
11
Sep 29, 2002 04:55 PM
gsrcivic20
Sep 13, 2001 06:16 AM
