fog lights not workin right
Old Mar 20, 2008 | 02:09 PM
nudvl's Avatar
Default fog lights not workin right
ive a 92 eg Ive oem style aftermarket fogs on it. I used the harness i got with them and hooked them up like ur supposed to, been workin great for a week now!!! well all of the sudden they are not workin right. when i cut on the head lights(low beam) and the swith for the fogs is on the fogs do not work!!!! but when i cut the the head lights off completely and the fog light switch is on the fog lights turn on. fuses are fine wiring is good. IM CONFUSED!!!!!!!!! oh and get this my horn quit workin after i hooked all this up last week and now that the lights are messin up my horn is workin again but it sounds funny
UR THOUGHTS OR FLAMES
Old Mar 20, 2008 | 03:09 PM
fryguy190's Avatar
Default Re: fog lights not workin right (nudvl)
you might have a short somewhere. i had i bit of the same problem. the brown/ or yellow wire you have that goes to the switch you might want to check at the fuse box.
Old Mar 23, 2008 | 01:02 PM
nudvl's Avatar
went through last night check wiring and connections on everything everything is good!!!! the relay was burnt up is wet sum how so i replaced that and now it keeps blowin fuses!!!!
I had a 40amp relay on it with a 30 amp fuse.
i replaced with a 30amp relay and kept the 30amp they came on fine then the fuse blew. whats the deal???????????????????????
Old Mar 23, 2008 | 01:13 PM
billllll23integra's Avatar
Default Re: (nudvl)
if u want u can try 2 put a resistor in beetween the line 2 lower teh current 2 it mite not blow it then.. or u have sumthen else blown out and its taken the power thats not being used on the blown circuit and directen it 2 ur lites 2 make it blow..
Old Mar 23, 2008 | 01:46 PM
nudvl's Avatar
ive checked everything else in the car lights, fuses, etc. its all good
Old Mar 23, 2008 | 03:51 PM
nudvl's Avatar
anything???
Old Mar 23, 2008 | 07:58 PM
nudvl's Avatar
still blowin fuses im triple checked everything
Old Mar 27, 2008 | 04:07 PM
nudvl's Avatar
new relay checked wiring moved ground rechecked everything and the FUSE KEEPS BLOWIN ANY IDEAS
Old Mar 28, 2008 | 09:35 AM
amdpro's Avatar
sounds like a ground problem
Old Mar 28, 2008 | 11:31 AM
nudvl's Avatar
well ur a smart 1
Old Mar 28, 2008 | 11:44 AM
over_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nudvl &raquo;</TD></TR><TR><TD CLASS="quote">I used the harness i got with them and hooked them up like ur supposed to,</TD></TR></TABLE>
thats your problem. Had you hooked them up the way your supposed to, they would work.
If you really checked it you would have found a problem already.
so go check it.
Old Mar 28, 2008 | 07:37 PM
nudvl's Avatar
Default Re: fog lights not workin right (OVNI_CIVIC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OVNI_CIVIC &raquo;</TD></TR><TR><TD CLASS="quote">
thats your problem. Had you hooked them up the way your supposed to, they would work. If you really checked it you would have found a problem already.
so go check it.
Are you serious!!!??? I really wish you lived close by so I could show you how much of a dumbass you really are!!! What part did you not catch "they worked fine for a week the relay got wet and fried, so i replaced and now it keeps blowin fuses"!!!
Anyway I have rechecked the harness and rehooked everything back up they worked fine till I started the car and turned them on the fuse again.
Old Mar 28, 2008 | 08:13 PM
nudvl's Avatar
Old Mar 28, 2008 | 09:57 PM
actek23's Avatar
Default Re: (nudvl)
check if any wires are exposed where it ate through the insulation. if any wires are exposed then you will be blowing fuses.
Old Mar 28, 2008 | 10:17 PM
nudvl's Avatar
I looked over the whole harness 2day and didnt notice anything like that
Old Mar 29, 2008 | 11:34 AM
VN712's Avatar
Default Re: (actek23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by actek23 &raquo;</TD></TR><TR><TD CLASS="quote">check if any wires are exposed where it ate through the insulation. if any wires are exposed then you will be blowing fuses. </TD></TR></TABLE>
I think he's on the right track. You probably have bad wirings from inside the insulation. I have the same problem too, but mine is off completely. I thinking mine have bad wires, due to the fact that I checked through everything and couldn't fine a solution to it.
I hope that help in one way or another.
Old Mar 29, 2008 | 12:12 PM
lponcian5799's Avatar
are your wires wrapped in a thicker insulator, not the wiring insulater but another to keep them together? what happened with mines is that i had a ground problem at first, then the wires heated up and they melted together inside the insulation causing a major burnout.
Old Mar 29, 2008 | 10:42 PM
nudvl's Avatar
No nuthin like that. I think I figured it out 2night its the cheap *** switch that came with the foglights!!!! sumthing is loose on the inside cause a short of sumkind causin the fuse to blow. now i just gotta find a factory 1 and wire it in
smackdown
Mar 10, 2010 11:48 PM
benji7288
Dec 29, 2007 08:33 PM
defaced8
Aug 27, 2007 05:35 PM
stupidwhitecat
Nov 5, 2005 04:26 AM
Mark Murda
Nov 5, 2004 12:43 PM
