Cat O2 sensor...can it be bent?
Old Jul 8, 2002 | 08:00 PM
Tommy_Gunns's Avatar
Default Cat O2 sensor...can it be bent?
Ok...the answer is probably no
But, I wanna check anyways
I have clearance issues with my cat O2 sensor hitting against my shift linkage and extension arm. If I could bend or shave off 5 mm it would greatly help my situation.
Old Jul 8, 2002 | 08:03 PM
Chris's Avatar
Default Re: Cat O2 sensor...can it be bent? (Tommy_Gunns)
I had the same problem in my 98 GSR with the ST sway bars.
the answer is YES.
BUT: make sure you use an old o2 sensor and alot of heat (torch) and just bend it. BE CAREFUL not to oval out the hole.
Heat around the base and gently bend it in the right direction. You will have to remove the shielding. It will not hurt the CAT.. its used to getting that hot.
I did mine at a muffler shop.
Old Jul 8, 2002 | 08:46 PM
Default Re: Cat O2 sensor...can it be bent? (Chris)
pics please
Old Jul 8, 2002 | 08:49 PM
Chris's Avatar
I dont have any.. sorry..
But to try to be helpful.. it looks like the base of the 02 sensor (the threaded mounting hole) was crushed in a little.. but very hard to notice.
Old Jul 8, 2002 | 08:50 PM
How much did you bend it (angle)?
Old Jul 8, 2002 | 08:54 PM
Chris's Avatar
Just to clarify, I did not bend the actual 02 sensor, but the CAT and the mounting bung it fits into...
It was moved just enough to clear the sway bar.
The hole started to oval, so we stopped.
Old Jul 9, 2002 | 02:28 PM
ttt
b 1 6 e g
Feb 27, 2006 11:29 AM
camil212
Jan 17, 2006 10:44 PM
joshcivic00
Nov 11, 2005 10:49 PM
IronQQQ
Aug 27, 2003 08:52 AM
intekragsr
Feb 4, 2002 06:35 AM
