Start up issues. searched........
Old Mar 19, 2008 | 07:12 PM
JDM-EJ698's Avatar
Default Start up issues. searched........
I have 98 civic hb with an ls/vtec.Ok
Well the problem I have is when I start the car it misfires for about a minute then it normal.I have NO check engine light.I put in a new dizzy,plugs,wires.Also when I start it I have to give it gas or else it dies.(just for starting it.)(While its misfiring.).Im kinda stump on what it could be.Once it stops misfiring its fine.idles like normal.Also when I'm slowing down and keep it gear it backfires (once) then I put it neutral and it shuts off.Any help would aprieciated.Thanks
Old Mar 19, 2008 | 09:02 PM
obuhmyuh's Avatar
Default Re: Start up issues. searched........ (JDM-EJ698)
dizzy, ignition module?
Old Mar 19, 2008 | 09:32 PM
cherroneballs's Avatar
I think your plug wires are switched. especially if it backfires.
Old Mar 20, 2008 | 04:29 AM
JDM-EJ698's Avatar
Default Re: (cherroneballs)
Well my dizzy is pretty new.I've also swaped with friends with no results.My plug wires are in correct order.Ignition module?how can I check that?It backfires only once then it dies.
Old Mar 20, 2008 | 07:17 AM
JDM-EJ698's Avatar
Default Re: (JDM-EJ698)
bump
Old Mar 20, 2008 | 07:23 AM
ho bag's Avatar
How low is your base idle?
My friends car was doing the same kinda thing when i got it and my base idle was so low the car would not idle if you unplugged the IACV. Try warming the car up and then unplugging the IACV and see if the car stalls.
Old Mar 20, 2008 | 03:36 PM
JDM-EJ698's Avatar
Default Re: (ho bag)
It idles around 750~800
Old Mar 20, 2008 | 06:06 PM
JDM-EJ698's Avatar
Old Mar 21, 2008 | 07:23 AM
JDM-EJ698's Avatar
Any more ideas?
Old Mar 21, 2008 | 10:46 AM
obuhmyuh's Avatar
https://honda-tech.com/zerothread?id=1430824
info in ICM and ignition coil check ^
also: how is your alternator doing? have you tried testing that?
Old Mar 21, 2008 | 01:55 PM
JDM-EJ698's Avatar
Default Re: Start up issues. searched........ (obuhmyuh)
My dizzy is new.but I've also swaped with friends and still does it.Alternator is fine.I'm just missing almost everytime at start up then it clears up.
Old Mar 21, 2008 | 02:06 PM
obuhmyuh's Avatar
what do you mean by clears up? like it runs fine after that?... id honestly probably just leave it alone if it runs fine... but if you wanted to further diagnose id start with plugs, and my fuel system after i checked the dizzy and the ignition coil.
Old Mar 21, 2008 | 04:07 PM
backfiring prety much means timing, or injector wires or plug wires are switched somethings hitting at the wrong time.
Old Mar 23, 2008 | 04:22 AM
JDM-EJ698's Avatar
Well it misses for the first 30-45secs at start up,but clears up and idles fine.but I have to give it gas or else it will shut off.
Old Mar 23, 2008 | 06:45 PM
obuhmyuh's Avatar
my car did that too, but it stopped when i replaced some damaged plugs on my harness, and fixed all my grounds.
GraphiteMW
Feb 1, 2007 06:37 AM
toonces
Jan 22, 2004 09:52 AM
jcivicsib20
Mar 13, 2003 08:42 AM
griffey_ny
Oct 24, 2002 09:22 AM
wdyno
Oct 14, 2001 12:02 PM
