HELP! Mini-Me swap problems.
Old Mar 19, 2008 | 05:54 PM
ctownintegra's Avatar
Default HELP! Mini-Me swap problems.
On a Buddy's 1994 Del-Sol. He put on the D16z6 head, and p28 Ecu. New plugs, T-Belt, wire ran for Vtec. It's all back together but will not crank. It is getting spark and fuel, but will not run. What should I check?
Old Mar 19, 2008 | 06:03 PM
crazyguy's Avatar
Default Re: HELP! Mini-Me swap problems. (ctownintegra)
main reley and ecu fuse.all the ground wires
Old Mar 19, 2008 | 06:53 PM
Those are all fine. All sensors are plugged up. The P28 doesn't look for a knock sensor does it?
Old Mar 20, 2008 | 08:32 AM
teal_dx's Avatar
Default Re: (ctownintegra)
no knock sensor on P28.
double check plug order and timing using the marks on the crank pulley?
Old Mar 20, 2008 | 08:35 AM
HONDACIVC93's Avatar
yeah check your timing make sure your not 180* degrees off on your cam gear. is it JUST turning over or is catching and stumbling like its trying to start?
Old Mar 21, 2008 | 07:36 PM
Got it to run tonight, it has a terrible idle though and no power, almost 100% sure it is in the timing. Thanks for your help and wish me luck tomorrow.
midorigreenmobi
10
Mar 30, 2014 03:42 PM
ecko22
Aug 8, 2012 06:52 AM
tibbits_b16
12
Feb 6, 2009 11:46 AM
jonnybravo
Feb 25, 2002 05:58 PM
