Could this be a distributor problem?
so whenever i start my car, it runs really rough until it warms up after a few minutes. i have to gas it during this time or else the RPMS will drop too 100 and almost die. Once its warmed up it runs okay 40% of the time. The other 60% of the time at a stoplight the idle will drop to like 400 or lower at times. I have changed my sparkplugs, wires, cap & rotors. I tested my battery and alternator and get perfect voltage readings. I also cleaned my IACV+throttle body. So is this my distributor causing this? any help is appreciated
Yea thats crazy, it would help to know what codes its throwing if any. I had this problem and it was wires, I would have to say this is an ignition module problem, which is inside the distributor.
if you haven't driven the car long, it wouldn't be enough to throw a code, usually takes 10 minutes or so for that one to pop up. it should be throwing CEL #8 like everyone elses civic is recently lol. that is DEFINITELY a dizzy problem.
nnope its not throwing a code at all which i thought was strange, but i guess theres no avoiding it and i'll have to be changing the distributor. any other ideas anyone?
BUMP!
BUMP!
oakpwr
Sep 12, 2008 08:12 AM
girlieracerk
Dec 18, 2003 10:12 PM
