itr engine start button
Old Mar 19, 2008 | 01:05 PM
laurensdc5's Avatar
Default itr engine start button
has anyone fitted an engine start button yet?
did you replace your mirror controller with the start button?
where else can it go like it belonged there?
what happens to your key ignition?
Old Mar 19, 2008 | 02:02 PM
rsxpat's Avatar
Default Re: itr engine start button (laurensdc5)
you'll still need the ignition key to turn it forward to the 2nd aux possition to unlock the steering wheel and send power to the relay that will be in-line with the new momentary button. once the key is turned forward, press in the cluth (if its a manula trans) and press and hold the button until the engine turns over, then release the button. all the button does is take the place of having to turn the key all the way forward to start it.
Old Mar 19, 2008 | 02:10 PM
Perfectionist's Avatar
Default Re: itr engine start button (rsxpat)
And if all cars came with a start button, I'm sure the hottest new trend would be to combine the start funtion into the ignition key cylinder so you can start the engine with one simple smooth twist of the wrist instead of going through all the other gyrations. Whatever makes you happy....
Old Mar 20, 2008 | 02:54 PM
johnclaunch's Avatar
Default Re: itr engine start button (Perfectionist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Perfectionist &raquo;</TD></TR><TR><TD CLASS="quote">And if all cars came with a start button, I'm sure the hottest new trend would be to combine the start funtion into the ignition key cylinder so you can start the engine with one simple smooth twist of the wrist instead of going through all the other gyrations. Whatever makes you happy....</TD></TR></TABLE>
So true...
Old Mar 23, 2008 | 10:25 AM
JDM_Matter's Avatar
Just get this from ICB http://WWW.JDMLAND.COM and ill go in the stock ITR position after that just get a S2K push button start switch.............
K20A_EH
Audio / Security / Video
Sep 6, 2009 02:41 PM
meagainsttheworld
Sep 16, 2007 05:11 PM
kai-chun
11
Oct 22, 2006 11:03 AM
natebest2000
Honda S2000
Feb 15, 2005 12:59 PM
ladeevtec
12
Nov 2, 2002 06:51 AM
