1992 Honda Accord LX Coupe Won't Start After Compression Test??
Old Mar 19, 2008 | 11:26 AM
Johnny916's Avatar
Default 1992 Honda Accord LX Coupe Won't Start After Compression Test??
Hi, I did a compression test on my 1992 Honda Accord LX Coupe Automatic with 269k miles.. The reason why I did the test was because the vehicle was lacking power and accelorated very slow from a stop.
Well after doing the test the car won't start! I have no idea as to why because before it started right up. I've checked all spark plug wires and the coil wire and they're all inserted correctly! Please help!
Here was my compression specs, can you guys tell me if this is normal??
Cyl 1 = 234, Cyl 2 = 225, Cyl 3 = 220, Cyl 4 = 230 according to my compression tester.
Old Mar 19, 2008 | 12:18 PM
Derek128's Avatar
Default Re: 1992 Honda Accord LX Coupe Won't Start After Compression Test?? (Johnny916)
wow
thats pretty high for a 16 yrs car
Old Mar 19, 2008 | 12:54 PM
AccordEX1991's Avatar
Do you have spark?
Are the plug wires in the correct order?
Old Mar 19, 2008 | 02:02 PM
Johnny916's Avatar
Default Re: 1992 Honda Accord LX Coupe Won't Start After Compression Test?? (AccordEX1991)
It's cranking pretty strong, just like when I was doing the compression test. How do I check if I have spark?
Old Mar 19, 2008 | 03:01 PM
Johnny916's Avatar
The wires are in the exact order as when taken off.. Which is when it started fine.
nuggets
Nov 16, 2007 03:12 AM
shabasoft
Jan 10, 2005 12:28 PM
J-g-D-s-M-r
Sep 29, 2003 02:32 AM
B_1_8_hatch
Jun 22, 2003 07:42 AM
smslude
Feb 25, 2003 10:40 AM
