Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
my next racecar
Old Mar 19, 2008 | 11:20 AM
ZUL8R's Avatar
Default my next racecar
J/k its Melissa's daily driver
she needed something better than the CRX
we just picked it up a few nights ago. 5th gear has a grind and i cant seem to shift it right yet it will be a 4spd when i drive it
Old Mar 19, 2008 | 11:38 AM
E-AT_me's Avatar
Default Re: my next racecar (ZUL8R)
HPDE time!!!
Old Mar 19, 2008 | 01:10 PM
mlrmotorsports's Avatar
looks clean
Old Mar 19, 2008 | 02:31 PM
smokin rubber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZUL8R &raquo;</TD></TR><TR><TD CLASS="quote">J/k its Melissa's daily driver </TD></TR></TABLE>
quoted so you cant race it, and remember even autoX is a timed event.
Old Mar 19, 2008 | 02:35 PM
Lo-Buck EF's Avatar
i know where you can get an lsd trans for it
Old Mar 19, 2008 | 02:37 PM
ZUL8R's Avatar
Default Re: my next racecar (smokin rubber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokin rubber &raquo;</TD></TR><TR><TD CLASS="quote">
quoted so you cant race it, and remember even autoX is a timed event.</TD></TR></TABLE>
Uh Oh! Ive already tried to register for the next local Auto-X but its not open Yet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lo-Buck EF &raquo;</TD></TR><TR><TD CLASS="quote">i know where you can get an lsd trans for it </TD></TR></TABLE>
Where?
Modified by ZUL8R at 6:42 PM 3/19/2008
Old Mar 19, 2008 | 03:02 PM
Kamin's Avatar
but HPDE 1-3 is not
Old Mar 19, 2008 | 04:18 PM
I hope you were just adding some oil
Old Mar 19, 2008 | 04:27 PM
ZUL8R's Avatar
I hope you were just adding some oil</TD></TR></TABLE>
I was changing the oil It was like hershey sysurp. it got a clean air filter too.
Old Mar 19, 2008 | 04:38 PM
Another Drew's Avatar
5th gear has a grind and i cant seem to shift it right yet it will be a 4spd when i drive it </TD></TR></TABLE>
My sister has the same gen prelude and she also has a 5th gear grind. Try letting the rpms drop to idle while coasting in neutral before you try to put it fifth.
Her prelude is my next race car too It's been sitting undriven for almost a year now since she bought a new car.
Old Mar 19, 2008 | 04:47 PM
I also have an old accord tranny that will bolt up and give some good mpg
Old Mar 19, 2008 | 04:49 PM
luder94-ChrisA's Avatar
Default Re: (Lo-Buck EF)
I think Spencer was refering to me. My track car has the 4th gen prelude JDM LSD transmission (M2B4) in it. Bolts up to any H22/H23 regardless of 4th or 5th prelude generation. Stock LSD in it, but the 3rd, 4th & 5th gears are too long for the track. On stock 225/50 ratio, 3rd tops out around 95, 4th tops out in the low 120's, & 5th gear would go to a theoretical 160+ mph.
I ended up buying another USDM transmission, as the final drives available for the prelude do NOT fit into the JDM cases. So, after I put the new FD & a new quaife in the new transmission, I'll swap the JDM LSD transmission out of the car. I'll probably have it for sale sometime in late April/early May.
If you do ever want to turn the car into a racecar, I'd avoid the JDM transmissions (as the FD won't fit). However, if you just want to autocross it every once in a while, the stock LSD works great & the first two gears work well for autocross.
Old Mar 19, 2008 | 05:18 PM
Lo-Buck EF's Avatar
Default Re: (luder94-ChrisA)
thank you chris
Old Mar 19, 2008 | 05:33 PM
gotta_race's Avatar
Not all of us forget to put the cap back on!
Old Mar 19, 2008 | 07:00 PM
Mario_D's Avatar
Default Re: my next racecar (gotta_race)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gotta_race &raquo;</TD></TR><TR><TD CLASS="quote">
Not all of us forget to put the cap back on! </TD></TR></TABLE>
Wow....that was a great reply. Heck, this is is just a good...
Old Mar 19, 2008 | 08:38 PM
Default Re: my next racecar (Mario_D)
its ok, you had to be there
Old Mar 19, 2008 | 11:19 PM
iam7head's Avatar
Default Re: (smokin rubber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokin rubber &raquo;</TD></TR><TR><TD CLASS="quote">I also have an old accord tranny that will bolt up and give some good mpg</TD></TR></TABLE>
wasting the motor by doing so?
just grab another h22 gear box and be done with it
Old Mar 20, 2008 | 04:24 PM
ZUL8R's Avatar
Default Re: (iam7head)
by the way,, what class do i sign up for at the next solo event? Do i hear PAX FTD
llslick
24
Sep 26, 2008 08:01 PM
njracer
Feb 5, 2008 09:01 AM
yakitori
54
Jan 21, 2004 09:18 AM
eg686
28
Jun 17, 2003 10:31 PM
