afc problem...
I have an S-AFC on my 94 LS, and when I change the settings it doesnt seem to do anyhting. For instance I can lean my car out -50% at low throttle on 1000 rpm, and the car will not stall, where as m friends si can only be leaned out like -35% then his car will stall. Also I had my car at +40% fuel on high throttle thru out the power band, and it will not add the fuel.
So in short I am runnin lean as hell right now, and the AFC will not richen it up at all! Has anyone else had this problem?? What would you do to fix it? Can anyone post an exact wiring diagram for the S-AFC on a 94 LS?? Thanks alot.
Any trouble codes?
The AFC and V-AFC can only add a certain amount of fuel, until the injectors are maxed at the current pressure setting. From what I have seen, 20-25% is about all either one is good for on stock pressure and stock injectors.
Try bumping up your fuel pressure if you are still lean, then retune the V-AFC...
Jason
Jason
Any trouble codes?
Jason
Jason
89 CRX SI
Feb 3, 2004 06:01 PM
