wheel is loose
Old Mar 18, 2008 | 08:52 PM
rbizzell30's Avatar
Default wheel is loose
I replaced the bad front passenger side wheel bearing and tighten everything. If I grab the wheel at the top and the bottom I can move it back and forth a little bit and I know it shouldn't do that after I just replaced the wheel bearing. What should I check to see what is causing this. I have a 1992 Acura Integra LS 4 door sedan? Thanks for your help
Old Mar 18, 2008 | 09:24 PM
supracrx's Avatar
lower ball joint, control arm bushing.
Old Mar 19, 2008 | 05:54 AM
Kasper_B
Guest
Posts: n/a
Default Re: wheel is loose (rbizzell30)
maybe tie-rod as well?
Old Mar 19, 2008 | 06:54 AM
jhammond_82's Avatar
Reject Papi
Default Re: wheel is loose (Kasper_B)
are you sure you tightened everything?
Old Mar 19, 2008 | 07:10 AM
rbizzell30's Avatar
Default Re: wheel is loose (jhammond_82)
I checked again yesterday and made sure everything was tight
Old Mar 19, 2008 | 08:05 AM
hatchling37's Avatar
You didn't press the bearing in properly. Try again.
Old Mar 19, 2008 | 09:03 AM
rbizzell30's Avatar
Default Re: wheel is loose (hatchling37)
I used this tool and pneumatic gun to press the bearing back in. Should I try it again
Old Mar 19, 2008 | 09:08 AM
rbizzell30's Avatar
What is the correct way to press the bearing in. I used this tool
FWD FRONT WHEEL BEARING ADAPTORS Remove and replace front wheel bearing with the steering knuckle and strut assemply still on the vehicle. Makes jobs easier and eliminates the need for a front end alignment after the service work is done. Works on both domestic and import front wheel drive cars and light trucks. Thanks!
Modified by rbizzell30 at 10:14 AM 3/19/2008
Old Mar 19, 2008 | 11:45 AM
dwamp2006's Avatar
try tightening the axle with a 1/2 impact, get that sucker tight as hell then try and see if it moves
Old Mar 19, 2008 | 12:11 PM
Dogginator's Avatar
Daisy... Daisy...
The Hub Tamer?
ketchup
17
Jun 27, 2008 09:02 PM
RSD
Feb 17, 2006 01:05 PM
Archie_G
Nov 18, 2003 01:39 PM
Takeoff
Feb 23, 2003 11:11 AM
