VSS stopped working..again!
Alright ive got a 93 civic ex with the stock z6, awhile back my vehicle speed sensor went out so i got a new one, put it in and it worked great, after 3 months of the car sitting, the VSS doesnt work now (speedometer and odometer dont work)..any ideas why after only 4 months the vss would go bad?? and i read on here that VTEC won't engage if the vss is not working, is this true and applies to me????
my speedometer for some odd reason starts to work after i engage vtec. pretty weird huh? like when i start the car and drive it'll be at 0.....then it'll jump up and down like crazy from 40-100mph then once i hit vtec.....it'll perform at reg rpm.
I HAVE NO IDEA WHY. but that's my car. good luck
I had this issue a couple of years ago, it ended up being a corrosion problem. I cant remember if it was in an ecu plug, or at the fuse box. If that helps any.
Modified by botlebruiser at 3:00 PM 3/19/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by botlebruiser »</TD></TR><TR><TD CLASS="quote">I had this issue a couple of years ago, it ended up being a corrosion problem. I cant remember if it was in an ecu plug, or at the fuse box. If that helps any.
Modified by botlebruiser at 3:00 PM 3/19/2008</TD></TR></TABLE> I had the same problem with corrosion. I took the plug apart and cleaned it but only worked for a little while. Ended up having to replace the plug. Try that.
November 18th
Feb 21, 2012 11:53 AM
aubreylorraine
Jun 15, 2010 04:44 PM
