rpm gauge going crazy
Old Mar 18, 2008 | 03:25 PM
bOOsted_D16's Avatar
Default rpm gauge going crazy
my rpm gauge is going crazy.......even the speedo gauge was moving,the car was idle........95 civic del sol.............any suggestions??
Old Mar 18, 2008 | 03:27 PM
devney's Avatar
Check the distributor. Just a guess.
Old Mar 18, 2008 | 03:45 PM
Default Re: (devney)
took it out ...put it back...same thing.......i'm thinking maybe a sensor...or the ecu
Old Mar 18, 2008 | 04:14 PM
z6hatchboy's Avatar
Default Re: (bOOsted_D16)
taking it out and putting it back i dont think will help. The rpm signal is gathered from the distributor so you probably need a new one.
Old Mar 18, 2008 | 04:46 PM
bunnyhatch93's Avatar
Default Re: rpm gauge going crazy (bOOsted_D16)
The tach is controlled by the blue wire on the plug going to the distributor and is controlled by the ignitor card in the distributor. On of them could be bad and i also had a bad alternator cause my tach to do some crazy shi7!
Old Mar 19, 2008 | 09:52 AM
Default Re: rpm gauge going crazy (bunnyhatch93)
problem solved............to all with this problem,be sure to check all ground wires,as this is where my problem was!!!!!!!!!!
topshotta
10
Mar 31, 2016 07:55 AM
shigun
Sep 29, 2014 06:00 AM
JDeez_1212
Sep 16, 2012 09:34 AM
totsie7944
May 26, 2007 01:33 AM
tigueremalo
Jan 28, 2007 11:24 AM
