clogged vtec stoleniod
Old Mar 18, 2008 | 02:21 PM
em1gangsta's Avatar
Default clogged vtec stoleniod
ok, so when i hit vtec, its not very loud. well a bout half as loud as it should be. can my stlenoid be clogged. is it clogged? if so, can i clean t out myself? i heard my friend did tat with his, or do i jst need to get a new one or get it tuned? help please?
Old Mar 18, 2008 | 02:51 PM
punkinbeck's Avatar
Default Re: clogged vtec stoleniod (em1gangsta)
yea your stlenoid might be clogged
Theres a screen in the stoleniod you can clean
but it could be about 20 different other things (usually isn't that simple)
Old Mar 18, 2008 | 03:00 PM
97Ej6mike's Avatar
Solonoids dont get clogged.
VTEC either works, or it doenst, there is no inbetween.
Old Mar 18, 2008 | 04:20 PM
em1gangsta's Avatar
Default Re: (97Ej6mike)
well it works. when i got on it tis afternoon and it was loud but im sure it can get clogged. how can a stolenoid not get clogged? it has oil in it, so as everything else in the engine that has oil in it, it has a chance to get clogged. some vtecs are a lil louder than others. how can i clean it?
Old Mar 18, 2008 | 05:57 PM
hondatuning1989's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">Solonoids dont get clogged.
VTEC either works, or it doenst, there is no inbetween.</TD></TR></TABLE>
if the filter is in it how could anything that could clog it get through?
Old Mar 18, 2008 | 07:29 PM
EG2Driver's Avatar
Default Re: (hondatuning1989)
its not the solenoid that you hear when VTEC engages...
Go to howstuffworks.com and see how it works.
Old Mar 18, 2008 | 07:34 PM
97Ej6mike's Avatar
Default Re: (EG2Driver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG2Driver &raquo;</TD></TR><TR><TD CLASS="quote">its not the solenoid that you hear when VTEC engages...
Nuff said
Do any upgrades recently to the intake or exhaust? Changing how air comes into and flows out of the engine can affect how VTEC sounds. For example, when i upgraded my intake, the sound of VTEC became less obvious because the intake sound was much deeper in general, drowning out the distinction between both. The same goes for exhaust upgrades.
Old Mar 18, 2008 | 07:36 PM
Hellraver's Avatar
lol your solonoid got stolen ... oid xD but no seriously whats a stolenoid hahahahahaha
ok ok ok really tho also try wikipedia.com...... solonoid engages vtec .... vtec actually comes from inside your engine ... know what a camshaft is?
Try this ... get a flat head screw driver and scrape off any dirt on your cam shaft scrape it good .... make that vtak engage loud!
Old Mar 18, 2008 | 07:47 PM
yoontim23's Avatar
There's 2 seal's on the soleniod one on the top and one on the side where it connect's to the head. Both has filters on them. And there's a lil wire thing thats on the soleniod push it all the way in the socket, If it's not in all the way then it's not going to crack. "MAKE SURE YOUR CAR IS WARMED UP FIRST"
Modified by yoontim23 at 8:58 PM 3/18/2008
Old Mar 18, 2008 | 07:58 PM
em1gangsta's Avatar
Default Re: (yoontim23)
ok guy from jacksonville. if thestolenoid doesnt engage vtec, then take yours off and see what happens. and im not going to scrape my cams. all i asked is if stolenoid could be clogged. if it cant, then say so, if it can, then good. the guy before me, thanks. foreal. lol i did make exhaust upgrades and i did get an intake but still, without them it still sounds a lil weak, but im sure theres nothing to worry baout
Old Mar 18, 2008 | 08:13 PM
Hellraver's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">ok guy from jacksonville. if thestolenoid doesnt engage vtec,</TD></TR></TABLE>
lol look gangsta you and your stolenoids dont do SHAT!
Now Solenoids engage vtak but it either does or doesnt, it does not partially start engaging the vtachkk lobes on your camshaft xD
PS - You should reconsider scraping the dirt of your cams. Use a chisel maybe.
Old Mar 18, 2008 | 08:33 PM
Hellraver's Avatar
if this is you ill send you 100$ right now i swear
http://youtube.com/watch?v=eBefX3E6VtY
Old Mar 18, 2008 | 09:29 PM
em1gangsta's Avatar
Default Re: (Hellraver)
no thats not me you moron. jst gtfo and have a nice day fool cuz im done. there is no vtec button. what do u drive neways? im guessing not a honda sice your calling it vtac all the time.
Old Mar 18, 2008 | 10:34 PM
Hellraver's Avatar
Yes there is a vtec button .... anyone know knows their way around honda can run a wire from the vtaK STOLENROID and make a button its quite simple actually, just retarded.
To be very very serious now, take your car to an import specialist and tell them you want a major tune up then the car fully compression tested and computer diagnostic tests run to make sure you have no misfire or anything you prolly have no clue is happening to your car and pay them whatever it is to get your car properly running.
Old Mar 19, 2008 | 03:33 AM
97Ej6mike's Avatar
The solonoid simply turns on or off VTEC. It doenst not determine how VTEC sounds. As mentioned before, its either on, or off, or neither (not working), there is asboluteley no inbetween.
Old Mar 19, 2008 | 09:28 AM
Mr.Highlife's Avatar
ima start callin it the vtizzec stolenoid
Old Mar 19, 2008 | 09:37 AM
suspendedHatch's Avatar
Default Re: (Mr.Highlife)
The weather can affect the sound of your exhaust. A change in elevation can affect the sound of your exhaust. A clogged VTEC solenoid screen can't.
Retarded Honda people make me embarrassed to own a Civic with an aftermarket exhaust. Sometimes I feel like king of the clowns.
I rue the day that someone came up with an idea to make the Fast and the Furious. If our cars weren't so cheap and so common, maybe we wouldn't have to bear the brunt of it.
Old Mar 19, 2008 | 09:38 AM
Soo... you're a gangsta from Texas? And you drive the same car my g/f drives..
mikeaitken
Apr 1, 2007 02:22 PM
superchargedex
Apr 14, 2005 12:14 PM
skafia
Jan 13, 2004 07:10 AM
Fraggle
Jan 12, 2004 12:15 PM
KTeller8
Dec 3, 2003 04:40 AM
