Help! 91 Power window won't go up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yomsantos »</TD></TR><TR><TD CLASS="quote">
my driver side window goes down but wont go up.
anyone know about this?</TD></TR></TABLE>
I do now. Maybe the switch? I don't know.
Welcome to the forum, and here's a suggestion. At least 90% of the posts are by people who need help. In the future, please include at least a hint of your question/problem in the title of your post. You stand a much better chance of getting replies from those who are knowledgeable about your problem. They may not always want to waste their time clicking on a post titled "Help".
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator »</TD></TR><TR><TD CLASS="quote">Window regulator or window switch.</TD></TR></TABLE>
Yup, that sums it up. You can sometimes 'fix' your window motor. It's just a simple wound copper coil with brushes. What happens is copper coil gets dirty and the brushes cannot make contact. Just take it apart, clean the coil & brushes with 200 grit sand paper and put back together. I'd say that 75% of the time this will do the trick.
As for the window switch part, one window switch (either driver or passenger side) causes the window not to go up - then the switch is the problem. However if you try both switches (passenger & driver side) and the problem is still there - then the switches are probably fine - your window motor might be the problem.
EX-T
Dec 2, 2003 03:53 PM
