engine help?
Old Mar 17, 2008 | 10:50 PM
DRGnzo's Avatar
Default engine help?
When changing pistons from low comp turbo setup to high comp all motor is machine work nessecary for piston clearances?
Old Mar 18, 2008 | 10:35 PM
badboyr66's Avatar
Default Re: engine help? (DRGnzo)
As far as clearance i asume you mean piston to cylinder wall clearance. And the answer is yes. The new pistons will be overlapping the area where the old pistons finished their stroke. If you have ever felt the inside of a cylinder wall you can kinds feel where the piston stops moving upward. The pistons needs the same measurment throughout it's duration of stroke.
So he machine shop would "hone" the cylinder walls to insure that every cylinder is the same for the piston the block is to revieve.
If you have any other questions... ask me when you see me. I will grab the blunt wrap on the way
But I hope I answered yer question
Old Mar 18, 2008 | 11:29 PM
DRGnzo's Avatar
thanks man it does.......
giomfe
Nov 19, 2006 09:00 AM
db2integra
Jul 27, 2004 11:44 AM
seako_916
May 19, 2004 08:52 PM
B20LS-T
May 13, 2003 04:17 PM
ZERO COOL
Mar 1, 2003 09:23 AM
