15/16 master cylinder with stock CX brakes?
Old Mar 17, 2008 | 07:52 AM
mental1's Avatar
Default 15/16 master cylinder with stock CX brakes?
I'm wondering if there will be any negative affects, if I put one of my 15/16 master cylinders in my car with the stock CX brakes. I'm wondering because yesterday and today it has started to lose pressure, but if I pump the pedal the brakes come back a bit. I'm also going to try just bleeding the system, is there anything else I should check, besides the lines of course. Thanks
Old Mar 17, 2008 | 07:56 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: 15/16 master cylinder with stock CX brakes? (mental1)
try bleeding it. that may be your issue. Make sure all the lines are on tight and leak free. The larger master cylinder will increase pedal effort for any given amount of braking power. Read up on fluid dynamics. More surface area at the force applied side means less force applied on the work side.
non-VTEC
Suspension & Brakes
May 29, 2011 02:45 PM
punkracer
Suspension & Brakes
Mar 15, 2010 01:32 PM
2old_honda
Apr 24, 2007 11:09 AM
mmuller
Jul 3, 2003 07:46 AM
ric3 daddie
Aug 20, 2002 11:33 PM
