Teg to EG Civic Brake Swap Parts List
Old Mar 16, 2008 | 11:27 PM
som3on3_10's Avatar
Default Teg to EG Civic Brake Swap Parts List
Ok, so I think I have all the parts needed to do a 94-95 Teg to EG Civic brake swap:
Front:
knuckle assembly
lower arm
upper arm
brake discs
calipers
Rear:
entire rear trailing arms
upper arm
lower arm
brake discs
calipers
Should that be it? Am I missing something or are there parts here that are listed that aren't necessary? Thanks in advance.
Old Mar 16, 2008 | 11:55 PM
BlueIntegraBoy's Avatar
Default Re: Teg to EG Civic Brake Swap Parts List (som3on3_10)
You need the soft brake lines as well as a 4040 prop valve and a larger master cylinder. You don't need the upper control arms. You can take the lower control arms to later add sway bars.
JR CIVIC
13
Aug 28, 2010 06:15 AM
commotion
Mar 2, 2009 01:23 AM
portfl0w
Aug 13, 2007 12:35 AM
civicjester
Aug 5, 2004 05:42 AM
hondahans
Jan 27, 2004 03:33 PM
