shift linkage or shifter problem!?
Old Mar 16, 2008 | 01:05 PM
aznej2's Avatar
Default shift linkage or shifter problem!?
My buddy just got done with a swap... d16y8 w/ z6 tranny in 93 civic. After hooking up the shift linkage the shifter was sitting far to the right I went over there to check it out but still cant figure it out? 1st gear is almost where 3rd should be and when in the middle (neutral) its slanted toward the passenger side... any suggestions? Thanks in advance
Old Mar 16, 2008 | 01:29 PM
crazyguy's Avatar
Default Re: shift linkage or shifter problem!? (aznej2)
check the shifter seating which is #11 in the pic shown below and also check all the bushing and make sure #26 is tight and check all the bushing. and also check if the end of the shift rod and extension are hitting against chassis
dsd1_209
Transmission & Drivetrain
Nov 1, 2012 06:53 PM
accordianex
Nov 11, 2006 09:13 AM
d!ckface
Oct 29, 2006 06:14 AM
G0crxG0
40
Apr 24, 2006 07:14 AM
BDogggUT34
38
Apr 11, 2005 02:19 PM
