California Residents!!! If you can get a swap to pass smog....
Old Mar 16, 2008 | 10:28 AM
Trouble's Avatar
Default California Residents!!! If you can get a swap to pass smog....
do you need to have the engine BAR'd?
Old Mar 16, 2008 | 10:32 AM
.Thomas's Avatar
Default Re: California Residents!!! If you can get a swap to pass smog.... (Trouble)
By the book, yes
depending on swap. if its a different series, then yes
Old Mar 16, 2008 | 10:59 AM
Trouble's Avatar
Default Re: California Residents!!! If you can get a swap to pass smog.... (TanCar)
it's a 92 cx w/ a 95 obd1 usdm gsr and obd1 usdm p72
Old Mar 16, 2008 | 11:40 AM
Luserkid's Avatar
In order to smog you need to go through BAR. If you go to a guy that doesnt care what motor you have thats called an "under the table" or "illegal" smog.
Old Mar 16, 2008 | 11:45 AM
bpkmrtoes's Avatar
if the motor passes the sniffer test then i would just make sure the visual is up to par. Then get the motor bar'd. Legit is the way to go... especially in California.
Old Mar 16, 2008 | 12:10 PM
mattyfo0z's Avatar
Default Re: California Residents!!! If you can get a swap to pass smog.... (bpkmrtoes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bpkmrtoes &raquo;</TD></TR><TR><TD CLASS="quote">if the motor passes the sniffer test then i would just make sure the visual is up to par. Then get the motor bar'd. Legit is the way to go... especially in California. </TD></TR></TABLE>
I agree.
Old Mar 16, 2008 | 04:23 PM
supereg2's Avatar
Default Re: California Residents!!! If you can get a swap to pass smog.... (Luserkid)
When your car is already BAR'ed, do you have to do it again when its time to smog you vehicle?
Old Mar 16, 2008 | 04:44 PM
iwannaboostmyteg's Avatar
Default Re: California Residents!!! If you can get a swap to pass smog.... (supereg2)
Yes even though you are Bar'd you still have to get the car smogged ever few years just like any other car in the state.
The only difference is they run the test according to what engine is marked on the Bar sticker so a higher emitting GSR say obviously wouldn't pass a test for a single cam y6 which doesn't emit as much. They use the parameters for the GSR to test the GSR swapped car.
As everyone else has stated. Get it Bar'd and you will save yourself lots of hastle and crap later.
Old Mar 16, 2008 | 05:11 PM
supereg2's Avatar
Default Re: California Residents!!! If you can get a swap to pass smog.... (iwannaboostmyteg)
I know that you have to smog it every few years but will you have to go BAR it again?
Old Mar 16, 2008 | 11:09 PM
bpkmrtoes's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by supereg2 &raquo;</TD></TR><TR><TD CLASS="quote">I know that you have to smog it every few years but will you have to go BAR it again?</TD></TR></TABLE>
If you get pulled over and the person decides to be a dick and has reason to believe your motor was modified further then you will have to be inspected again.
BRIANxJDM
35
May 11, 2013 09:49 PM
z0ngtoker
Dec 22, 2008 09:53 PM
SLOW_ASS_CRX
Aug 8, 2004 10:18 AM
bigbacon2
Jun 24, 2004 03:47 PM
00fbp
Nov 28, 2002 09:29 PM
