how do i erase code on the ECU
Old Mar 16, 2008 | 08:50 AM
fryguy190's Avatar
Default how do i erase code on the ECU
in my civic i recently put headers on it and i didn't put my O2 on right away so it brought up the code for it. but now its on and i unplugged the battery for 10 min and its still throwin the O2 code. I know the sensor works because we tried it in my buddies car and it works fine. is their a way i can reset the ECU so it wont through the code anymore?
THANKS...
Old Mar 16, 2008 | 10:04 AM
Former User's Avatar
Default Re: how do i erase code on the ECU (fryguy190)
You may have a problem with the O2 sensor circuit. Check the wires for damage (open or short) and the connector for corrosion.
Old Mar 16, 2008 | 09:14 PM
fryguy190's Avatar
Default Re: how do i erase code on the ECU (RonJ@HT)
ok thanks ill check on that in the morning.
Old Mar 16, 2008 | 10:21 PM
incubusjunkie614's Avatar
i also believe that autozone will read/ scan codes. its free too! just talk the guy into erasing the codes. if it comes back, then the problem is probably in your wiring
GEIJIN
Aug 7, 2009 07:56 PM
Hardedge
Feb 11, 2008 12:32 AM
the jdmchop
May 23, 2006 11:26 AM
00WhiteEKy
Aug 24, 2002 04:13 PM
