93 vx hatch, ls vtec with gsr wiring no spark..
well i got a vx hatch and i did the o2 re wire already, but im just not getting spark and im wondering if the other plug that is hanging on the firewall side has some ignition wires in it. Anyone know?
used different coil im not getting power to the rotor power is getting to the distributer though, clip to dizzy with 2 wires the blue wire is getting power coil is just not getting to rotor,, anyone? Also my fuel pump stopped priming why?
is the engine light on when you leave the ignition on?...cause that other guys prolly right you should check the adjustments on the distrubutor and see the manufacturers specs.
