Knock in the Block! Help
Old Mar 15, 2008 | 06:26 PM
sireg6's Avatar
Default Knock in the Block! Help
Ok well recently ive had i slight knock on startup but only every once and a while.. 1 MAYBE 2 Knocks then regular idle... I also get the Knock on occasion on a slow take off like sometimes when i roll from 2nd but it only stays for like 1000 RPM...Is just a very slight knock almost like an exhaust leak sound. I took the oil pan off and checked things out. Everything looked ok down there and i shook the rod end caps...Each one only had about a hair of play...
I keep thinking its the rod bearings Can someone Please help me diagnose it...
and if it is the bearings is it possible to just change them since it such a little noise and not constant?
Old Mar 15, 2008 | 07:13 PM
sireg6's Avatar
Default Re: Knock in the Block! Help (sireg6)
BUMP
Old Mar 15, 2008 | 10:06 PM
civicstar's Avatar
well usually sometimes once it warms up it will go away and is a typical symtom of the bearings, u might as well just drop the crank and repolish it and get new bearings
Old Mar 16, 2008 | 01:59 PM
sireg6's Avatar
Default Re: Knock in the Block! Help (civicstar)
thanks alot civicstar...i know this may be the cheap way but i currently have no air compressor and will be unable to remove the crank pulley bolt so dropping the crank isnt much of an option at this point..
Would it be possible for me to just pull the bearings and lube/replace them with new ones?
I only have to drive this motor for like 2-4 more months...
Old Mar 16, 2008 | 03:52 PM
crucian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sireg6 &raquo;</TD></TR><TR><TD CLASS="quote">thanks alot civicstar...i know this may be the cheap way but i currently have no air compressor and will be unable to remove the crank pulley bolt so dropping the crank isnt much of an option at this point..
I only have to drive this motor for like 2-4 more months...</TD></TR></TABLE> I tried that today and still got crazy knock. I think it might be the crank.
Old Mar 16, 2008 | 07:45 PM
civicstar's Avatar
well u can try that, if the bearing is the problem then that will fix it but if the crank is the issue, then u need to repolish and cut down and get oversized bearings. its up to u if u want to try
iwannarace
10
Jun 13, 2015 06:14 AM
Stonewall551
Aug 6, 2012 02:31 PM
Thepowderblue
Jul 28, 2012 12:09 PM
Tamotoji
May 14, 2011 02:29 PM
Ryan_G.
Feb 7, 2010 05:44 PM
