bored D16y5 to 75.5mm .... stock head gasket???
Old Mar 15, 2008 | 10:34 AM
RICE POLICE SIP's Avatar
Default bored D16y5 to 75.5mm .... stock head gasket???
I just thought about this last night.. I'm getting my Y5 bored out to 75.5 for a Vitara build... Now will I have to get the OEM gasket bored as well or can I just use it as is? Will I even notice a difference when installing it? Sorry if this seems like a noob question.. But this is my first SOHC build...
TIA
Shane
Old Mar 15, 2008 | 01:22 PM
KENetics1's Avatar
Default Re: bored D16y5 to 75.5mm .... stock head gasket??? (RICE POLICE SIP)
I think most oem headgaskets are bigger than actual stock bore so I think you should be fine using a oem gasket
Old Mar 15, 2008 | 06:41 PM
Default Re: bored D16y5 to 75.5mm .... stock head gasket??? (KENetics1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KENetics1 &raquo;</TD></TR><TR><TD CLASS="quote">I think most oem headgaskets are bigger than actual stock bore so I think you should be fine using a oem gasket</TD></TR></TABLE>
thanks! Can anyone confirm this?
Old Mar 16, 2008 | 04:23 PM
anyone else?
Old Mar 16, 2008 | 04:50 PM
KENetics1's Avatar
try using the search. I did and it pretty much confirmed what I said previously
Old Mar 16, 2008 | 05:13 PM
what did you search? I tried but didn't really find an answer to the question...
Old Mar 16, 2008 | 05:45 PM
KENetics1's Avatar
overbore+gasket
Old Mar 18, 2008 | 07:21 PM
inspyral's Avatar
You should be able to use the stock gasket for a .5mm overbore.
Eghatchgsr8
Sep 19, 2014 02:24 PM
MumBleZ_94gsR
Apr 16, 2009 09:37 AM
panda_eh2
Dec 12, 2007 01:35 PM
ProPerformance
Jun 16, 2007 08:25 AM
gowyeng
Feb 9, 2005 06:36 AM
