Bouncing Idle
Old Mar 15, 2008 | 09:39 AM
SR20S13's Avatar
Default Bouncing Idle
i've had a bouncing idle for awhile now, and i can't seem to find out whats wrong with it, i've replaced both the fast idle valve,IACV, i've sprayed every single vacume line i could see with WD-40, and still same thing, i sprayed both the top of the intake manifold gasket, and the throttle body gasket and still nothing? what could it be??? i'm ready to pay and arm and a leg and just let the honda dealership take care of it?
I have a 94 Civic LX (D15B7)
Old Mar 16, 2008 | 07:45 AM
SR20S13's Avatar
BUMP
Old Mar 16, 2008 | 09:41 AM
SR20S13's Avatar
BEFORE-WORK BUMP
Old Mar 16, 2008 | 09:57 AM
austinkli's Avatar
Default Re: (SR20S13)
map sensor maybe??? can't hurt to check.
Old Mar 16, 2008 | 10:02 AM
Former User's Avatar
Default Re: (austinkli)
Try bleeding the cooling system of possible air bubbles.
Old Mar 16, 2008 | 12:24 PM
Andersleet's Avatar
Default Re: Bouncing Idle (SR20S13)
Definately check your cooling system completely, I had that problem not too long ago and I didn't fully check my system and the end result was me shelling out 1200 for a shop to fix my block because the cooling system failed and warped the head.
Oh, and stay away from any of those "liquid miracles in a bottle", they didnt work when I tried. However it was extremely cold when I attempted it (35 degrees) but I still would not waste my money on that again.
Hope that helps.
Old Mar 16, 2008 | 01:09 PM
boostedjdmdc2's Avatar
Did you replace the IACV and FITV with ones that you are sure worked?
Any CEL?
Can you give us a little more info on when the idle is erratic?
Definitely bleed your coolant to see if theres air bubbles.
Old Mar 16, 2008 | 01:14 PM
oh and screw in the white plastic piece inside the FITV. that is sometimes the cause for hunting idles.
Old Mar 16, 2008 | 07:58 PM
SR20S13's Avatar
Default Re: (boostedjdmdc2)
there are no CEL's
my cooling system is bleeded, and yes i know they work becuase i changed to a Z6 manifold, and they worked before on my B7 manifold
i know its got to be a vacume leak someplace i just can't seem to find it
Old Mar 17, 2008 | 10:35 AM
SR20S13's Avatar
bump
Old Mar 17, 2008 | 06:14 PM
SR20S13's Avatar
bump bump bump
thekid2390
Apr 11, 2013 11:25 AM
chope045
Oct 24, 2011 04:12 PM
EKBOOSTDREAMS
10
May 27, 2006 08:46 PM
wedgenix
May 27, 2005 07:54 PM
SupaFly_Honda
Feb 26, 2004 05:12 AM
