Surging Idle
Surging Idle
I have a second gen B16 and i have a problem with my idle surging. I replaced the IAC valve and flushed the cooling system, it doesnt get hot or anything, the fan works and it will really only do it during the day when I drive it for like 20 minutes or so. Any ideas???
Re: Surging Idle (SIRTIM96)
did you bleed the cooling system? Normally the fan wont come on unless your low on antifreeze.. could be a possiblity..but not sure if it will have anything to do with idle
Re: Surging Idle (bmiller17)
I actually switched ecu's and still had the problem. So i put the old ecu back in and it went away, at least for now... if it comes back i will try all of the tips you gave me, thanks for the help.
Location: I put on my robe and wizard hat, NY...err Bay Area--->Texas
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmiller17 »</TD></TR><TR><TD CLASS="quote">did you bleed the cooling system? Normally the fan wont come on unless your low on antifreeze.. could be a possiblity..but not sure if it will have anything to do with idle</TD></TR></TABLE>
Huh?
I've never heard of this.
Huh?
Re: Surging Idle (HalfAnP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HalfAnP »</TD></TR><TR><TD CLASS="quote">
Huh?
I've never heard of this. </TD></TR></TABLE>
yeah...i had a couple buddies tell me that. Basically what they said was...the fan only comes on as a backup..for instance if you are low on antifreeze or the lines havent been bled.
Huh?
luv2boost
06-02-2008 06:33 PM
