ABS 2-1: How do I fix?
Old Mar 15, 2008 | 08:09 AM
Durg's Avatar
Default ABS 2-1: How do I fix?
My e-brake light and ABS light have been on in my '92 accord for a couple of weeks now, I finally got around to checking the number and found 2-1 Circuit of handbrake warning lamp switch. This makes since, as my E-Brake light has been on this entire time, so how do I fix this? New sensor or what?
Old Mar 15, 2008 | 08:37 AM
Chiovnidca's Avatar
Default Re: ABS 2-1: How do I fix? (Durg)
Usually just need to top off the brake fluid. Might be a good idea to check the brakes if the fluid is low.
Old Mar 15, 2008 | 05:21 PM
hondadude's Avatar
Look down in the slot where the hand brake lever is and see if a penny fell in there and is shorting the switch arm to ground.
And when you check the master cylinder brake fluid take the top off and look inside, often times there is a scum line in the reservoir that can be misleading if you just look at it.
malilaz
Suspension & Brakes
Nov 23, 2013 12:42 AM
nismok720
Mar 27, 2011 05:16 AM
supermotothud
Nov 10, 2008 04:09 PM
mikester_91
Jan 18, 2005 01:14 PM
tegon-gsr
Oct 21, 2004 12:15 PM
