Good news, got the Wiseco pistons and the Eagle rods.
Old Jul 8, 2002 | 10:49 AM
pinota's Avatar
Default Good news, got the Wiseco pistons and the Eagle rods.
Good news, got the Wiseco 82.mm piston kit - 11.5 CR and the Eagle rods, today.
My engine rebuilt wil be done in the next 15 days.
My Tecnauto ( one of the best shops here in Portugal ) mechanic is gona port and polish the head and port the throttle body to 70mm.
Got a few more mods: Spoon street disk, Hondata gasket, ARP head studs, new oil pump and i´m planning to get the Greddy a/f metter kit and a oil cooler.
Lets hope, everything will be ok.
Thanks to Larry , from theoldone i got them really fast and clean.
Pinota
Old Jul 8, 2002 | 10:53 AM
sgT's Avatar
sgT
Default Re: Good news, got the Wiseco pistons and the Eagle rods. (pinota)
remember, bigger fuel injectors and no speeding until you get tuned.
Old Jul 8, 2002 | 11:04 AM
Tommy_Gunns's Avatar
Wow 82 mm...what does that make his displacement if using stock rods and crank?
Old Jul 8, 2002 | 11:05 AM
pinota's Avatar
Default Re: Good news, got the Wiseco pistons and the Eagle rods. (sgT)
I got the B&M FPR and gauge. I also have V-AFC.
I always drive with 98 octane fuel, do you think i should get bigger injectors ?
I´m mechanic is planning to retard the timing, too.
I´m planning to get the Greddy A/F metter to tune it, cause there are no dynos here in Portugal with 02 wide band sensor.
I´ll post pics soon.
Pinota
[Modified by pinota, 8:07 PM 7/8/2002]
Old Jul 8, 2002 | 11:11 AM
Black R's Avatar
25 Year Member
.....get a diy wideband if that's the case - much more accurate than the greddy unit.
Also: you will probably need bigger injectors anyway (i don't know your cam setup), maybe some 310's at a minimum? Octane is good, but won't prevent you not being able to supply enough fuel at higher rpms.....
a j&s wouldn't hurt either - if you are running around untuned.....
good luck this time.
Old Jul 8, 2002 | 11:18 AM
CheezeFrog's Avatar
Nice... Sounds like a sweet setup for turbo!!!
Old Jul 8, 2002 | 11:22 AM
sgT's Avatar
sgT
Default Re: Good news, got the Wiseco pistons and the Eagle rods. (Tommy_Gunns)
About 1840cc
Old Jul 8, 2002 | 11:27 AM
pinota's Avatar
Default Re: Good news, got the Wiseco pistons and the Eagle rods. (Black R)
i´m running stock cams.
I got the 11.5 CR pistons to prevent some problms.
The euro ITR already have 11.1 CR stock, like the JDM.
So, i think the euro ECU fuel maps are already diferent from the USDM.
I´m raising the CR just 0.4, like i´m using a 2 layer gasket.
Old Jul 8, 2002 | 11:47 AM
Warren's Avatar
Wrong-Way Wang
I really don't understand why you're running such low compression pistons if you're going through all this trouble.
Warren
Old Jul 8, 2002 | 12:07 PM
pinota's Avatar
Default Re: Good news, got the Wiseco pistons and the Eagle rods. (Warren)
I just want to run safe.
It´s very hard to find god mechanics here in Portugal, that can handle and tune aftermarket parts for Acuras.
My Tecnauto mechanic is very good, he knows a lot about ITR´s but, he´s the best on scoobyes. You see, i´m afaid of new problems.
Old Jul 8, 2002 | 12:45 PM
00MRSi's Avatar
Since you have money to spend, you should have sgT do your motor..
Old Jul 8, 2002 | 03:18 PM
pinota's Avatar
Default Re: Good news, got the Wiseco pistons and the Eagle rods. (00MRSi)
You bet, i´m in Portugal.
If i whould be in US, sgT whould be the man.
sgT rules !!!
More thoughts on this ?
Bigger injectors to run this setup or B&M FPR and V-AFC will make it ?
I always use 98 octane gas.
Thanks,
Old Jul 8, 2002 | 03:22 PM
sgT's Avatar
sgT
you may be able to make due with just an FPR
Old Jul 9, 2002 | 12:37 PM
ITR21's Avatar
let us know how they are once you have them tunned.
Old Jul 9, 2002 | 03:15 PM
ITRbroham's Avatar
shit post warrior
Default Re: Good news, got the Wiseco pistons and the Eagle rods. (ITR21)
Good luck, Pinota
Old Jul 10, 2002 | 12:55 AM
pinota's Avatar
Default Re: Good news, got the Wiseco pistons and the Eagle rods. (ITRbroham)
Thanks,
I´ll post pics of the Wiseco pistons and Eagle rods later.
I already ordered the Greddy A/F metter warning kit from nippon power.
I hope i´ll be able to tune my engine properly with some acuracy with it.
There are no dynos here with wideband O2.
My mechanic told me today that i have to get all new valves.
Also 2 journals of crank are damaged, i´ll get all new crank journals.
Man, my mechanic told me that the rod journal are all blue, also the crank ones.
Let´s hope everything will work ok.
Pinota
Old Jul 10, 2002 | 04:13 AM
sgT's Avatar
sgT
replace the crank
you cant get new crank journals.
Old Jul 10, 2002 | 06:47 AM
pinota's Avatar
Sorry, it´s not the journals, it´s the bearings.
It´s the crankshaft bearings. All lower bearings need to be replaced, for safe.
Language mistake.
Old Jul 10, 2002 | 07:44 AM
pinota's Avatar
I´ll post pics today.
Pinota
Old Jul 10, 2002 | 07:52 AM
sgT's Avatar
sgT
You should replace the bearings anyway. but if they wore down already then
you have other problems you need to figure out first.
EscoSi
Oct 8, 2014 06:52 PM
chueflee
27
Jun 10, 2008 10:33 PM
Joeballz85
Mar 7, 2005 04:35 PM
T-Blaze
Oct 27, 2003 10:36 AM
lucas569
Aug 3, 2001 01:45 PM
